Rear view camera issue
Old Dec 27, 2017 | 04:32 PM
Hector Uriel Burela's Avatar
Unhappy Rear view camera issue
New here so I don’t know if it is the right place to post but I have a 2015 fit ex and since last night my rear view camera won’t turn off. It’s been on while I drive and I’m unable to even access the side camera nor the stereo features to like change radio station and so on. Anyone else has experience this issue? Would this be a covered under warranty?
Old Dec 28, 2017 | 08:16 AM
i dont think we ever figured out a way to reset just the HU on the GK's so wat id suggest is mark down your factory radio code (should be in your glove box somewhere) and then undo the ground (black wire) on your car battery. let it sit for 10min, and reconnect. this should (i emphasize should) reset your HU along with everything else on the car. if it doesnt reset your radio, leave the ground off for a couple of hours.
dont forget to jot down your radio code as if you dont have it, you will not be able to start your HU when you reconnect your battery.
if this doesnt work, i suggest talking to your dealer.. or check with your dealer first if you dont feel comfortable doing the above.
GL!
Old Jan 5, 2018 | 07:06 AM
2Rismo2's Avatar
Sounds like a warranty issue to me. So when you powercycle the car it is still stuck on the same screen? If so I'd get it over to a dealership ASAP so they can witness it otherwise they might give you a hard time about "not being able to replicate the problem"
Darlwy
Jan 9, 2019 10:33 PM
SilverEX15
Dec 2, 2018 02:53 PM
ncoflin
Nov 8, 2016 08:13 AM
nobody
Oct 27, 2016 12:44 PM
Mysticangel
Dec 9, 2014 04:16 AM
