car does not start and computer scanner does not read ecu
Old Jan 14, 2018 | 07:10 AM
Tawo's Avatar
good day guys i my honda fit cranks but dies not start. we have check the furl pump replaced it same thing. the relays checked, fuses checked same thing. it was then said that it was the ecu thats the problem becuz it was hot. i got a mechanic to use a scan tool to check the problem the scanner cud not connect with the ecu. tried another ecu same result gets heated and does not connect so we cannot get an idea of the problem. what do u advise that we do next
Old Apr 15, 2018 | 12:24 AM
Tawo's Avatar
i have the same problem
i have the very same issue so i am.awaiting on what should my next move be
Old Apr 15, 2018 | 09:03 AM
SR14626's Avatar
One post on this same subject is enough my friend.
Old Apr 15, 2018 | 10:00 AM
Tawo's Avatar
do you have any possible insight on the matter
Old Apr 15, 2018 | 03:43 PM
Tawo's Avatar
update: tried a scan tool again could not connect but the mechanic says there is no check engine light. what could cause this?
Old Apr 19, 2018 | 04:19 PM
Uncle Gary's Avatar
I'm not sure, but I suspect a disconnected wire somewhere. Check for rodent damage maybe? I'm told mice find the insulation Honda uses on their wiring to be very tasty.
Old Apr 19, 2018 | 06:48 PM
Fuelish's Avatar
Rodent damage not outside of the realm of possibility .....I had a '93 Celica burn it's electrical system up due to what was said to be chewed wiring. Of course, this happened AFTER the end of my shift, so I was stuck at work for a while.....when I got to work the evening before, the power door locks wouldn't work, figured, minor deal, locked it manually and figured I'd deal with it. Went to start it to go home in the a.m., no go and smoke coming from underhood.....had it towed to my mechanic, chewed/burnt wiring was the issue, and would've cost more to fix than the car was worth....and so it goes. Loved that car, but not enough to fix it LOL. On a newer car, yeah, I'd get to the bottom of it
Tawo
Dec 13, 2024 05:22 PM
Tawo
May 2, 2018 07:26 PM
Tawo
Apr 15, 2018 12:34 AM
DOHCtor
61
May 2, 2011 05:18 PM
McQueen
Jun 25, 2010 12:14 AM
