Help! LED's to fit Map Lights for 2018 sports?
Old Feb 17, 2018 | 11:37 PM
Aussie's Avatar
Anyone know what LED to get for map light in a 2018'?
The lights below were recommended but are too long- not allowing the button to click once the cover's reinstalled. They do fit, and you can put the cover back on but the LED protrudes beyond the button so when you depress the cover it's not able to make contact with the button.
Amazon Amazon
Thanks in advance. I've been researching for ages and can't find a thing.
Old Feb 19, 2018 | 01:15 AM
David Lawrence's Avatar
I'm using these. I got the 6K Crystal Whites. They're super bright and work well:
https://www.precisionled.com/premium...-5730-led.html
Old Feb 19, 2018 | 02:38 PM
Aussie's Avatar
Are they $10 each? And do you have a 2018? Just double checking they'll fit.
I just ordered the ones below. They're 1/4" shorter than the others and should fit. Not sure how bright they are but they're a buck each.
Thanks!
Amazon Amazon
Old Feb 19, 2018 | 04:05 PM
I have a 2015 but I'm pretty sure the map lights are the same in the 2018 as there are other interior parts that are interchangeable between the GK5 models including the 2018.
Yes, they're $10 each. They fit fine, are really bright, and are very high quality. That's why they cost a bit more. They're so bright in fact, that I didn't wind up using the third one I got for my dome as it was too much light. I wound up getting a dimmer LED for the dome.
The brightness depends on the LEDs used in the module. The Precision Premiums use 5730 modules which are brightest available in that form factor. The ones you ordered use 3030's which will be much dimmer.
https://www.12vmonster.com/blogs/pro...-5630-5730-led
If you wind up not being happy with the brightness with the ones you ordered, I think the Precisions are worth the cost.
Here's a photo so you can see the size.
Old Feb 19, 2018 | 10:33 PM
Aussie's Avatar
thanks so much. Great to finally get some good intel!
I couldn't figure out the unit of measurement for brightness with all these LED's. The initial ones I got for the cargo (which i also now have in the dome light are the ones below (suggested by another member). I can't tell which are brighter, the 3030 I just got or the Jtech's. I'm guessing by what you just said the "3528 SMD" would suggest the Jtech is slightly brighter. It was very hard to tell.
Amazon Amazon
Alas that's all my interior lighting done. Wonder what inexpensive mod I'll do next.
Old Mar 1, 2018 | 10:36 AM
Uncle Gary's Avatar
Here's what I used for my map lights on my '15.
Amazon Amazon
These were a perfect fit and cheap, too.
Old Mar 21, 2018 | 04:18 PM
calafricano's Avatar
in order to do the map light properly.and get crazy light out of them.you have to do some modifications.
the picture here is my homeboy with only the dome light on.
zongld
Dec 28, 2017 08:42 PM
Daniel.Lam
Dec 22, 2017 09:06 AM
person118
Jul 29, 2017 07:42 PM
MyFirstHonda
Jun 17, 2017 01:14 PM
