Possible cheaper source of tranny fluid from RockAuto by ASIN?
Old Mar 23, 2018 | 10:04 PM
RA080424's Avatar
Thread Deleted by Owner
This post has been overwritten during an account deletion process.
Old Mar 31, 2018 | 03:48 PM
preludes&fit's Avatar
hey bud,
I am super new the the Fit life, but a long time Honda driver. In my opinion, stick with Honda OEM for all fluids... I know what you are saying with Aisin being the OEM manufacturer, but I have been too scared to test it myself. In honesty, the way I think about it your ATF is going to last 15 - 30k... the cost difference is negligible. This doesn't make it easier to deal with stealership pricing in the moment, but overall... OEM has NEVER given me an issue and I have read tons of people's experiences about aftermarket liquids.
Just to share a bit more - NGK for ignition (spark, wires, etc.) and MOOG & KYB for suspension. Rockauto.com is a great source for parts, but I think there are some general rules to live by when it comes to aftermarket.
Old Mar 31, 2018 | 09:08 PM
Goobers's Avatar
I don’t really understand the need to get cheap fluids for critical parts that need to last a long time.
I mean how often does the transmission fluid need to be changed? 60k miles? 100k miles? It’s not like an oil change every 3k-18k miles.
On a side note, I’ve bought one part from Rockauto, a splash guard to replace the one that got damage from my road trip some 7 years ago.
I still haven’t swapped it, since the part I got from RA is flimsy as fuck and I’d rather use a damaged splash guard than that crap from RA.
Old Apr 1, 2018 | 07:36 AM
Carbuff2's Avatar
FWIW, DW-1 is ~$6.00/qt + shipping at the online Honda dealers as I type this (April 2018).
Automatic Transmission Fluid ATF DW-1 08200-9008 - $6.03
The change interval (single drain & fill) is 30K miles.
Old Apr 1, 2018 | 10:08 AM
SR14626's Avatar
And this is why I never buy a used car if all possible. Some people go on the cheap and unknown how they drove their car.
Old Apr 1, 2018 | 10:41 AM
sneefy's Avatar
$8-9 bucks for transmission fluid is not expensive. Ford makes a full synthetic fluid that's $18-25 a quart depending where you buy it.
Don't cheap out on transmission fluid. Fluid is cheap. A transmission is not.
Old Apr 1, 2018 | 10:43 AM
sneefy's Avatar
Unfortunately, like brake fluid, most owners don't follow change intervals for the transmission. Points for anyone that does!
Old Apr 1, 2018 | 05:56 PM
Goobers's Avatar
Which is about or less expensive than a quart of 0w-20 mobil synthetic. I'm not even sure exactly there is to even be saved from hunting for cheap trans oil.
Heh... oops, I went FAR longer than 30k miles. Mechanic said he didn't see anything wrong with my Fit once he did the transmission oil and axle change (when I snapped an axle).
Old Apr 1, 2018 | 07:32 PM
Carbuff2's Avatar
With me, it's the Thrill of the Hunt!
Old Apr 2, 2018 | 11:00 AM
bigdeezy's Avatar
I’ve used a few different transmission oils in my 2013 Fit. No issues yet. I used Honda OEM for a 4 drain and fill at 30K. At 60K I used Walmart SuperTech Low Viscosity Full Synthetic transmission oil for a 2 drain and fill and put a new Honda OEM filter on. At 90K I used Castrol Import Multi-Vehicle transmission oil for a 2 drain and fill. At 120K, another 2 drain and fill with Castrol and a Honda OEM filter. All oils explicatly met the Honda DW-1. I did notice that the Castrol oil takes longer to warm up in cold weather and shifts more abruptly until warmed up. Next time, I will use the Walmart and do a 4 drain and fill. I’ll use Walmart from here on out. It’s just under $6/qt, meets the required standards, and shifts just fine. As long as the oil meets Honda’s requirements you’re good. It’s like engine oil... meet the requirements and you’re good.
Also, I drive the heck out of my car. I drove 65,000 miles as a courier last year alone. I’m on track to drive just as much this year as well.
Old Apr 2, 2018 | 11:31 AM
The original question was is anyone could verify Aisin as the OEM provider, unfortunately I don't think that anyone will know that answer. You are probably right, but unless someone is a Honda tech... no way to confirm.
Off topic - first gearbox flush (MT) for a new car at 5k? I will change the engine oil at 1000, per usual break in period... but wasn't sure about the tranny? Ideas?
Old Apr 2, 2018 | 01:51 PM
Carbuff2's Avatar
I've replaced both my Honda's MT fluids at 25 - 30K miles (about 2 years). No issues at 150 - 180K miles on our MT vehicles.
A friend who never changed his until 80K miles on his Acura RSX couldn't believe the difference in shift quality!
PS: Some Honda owners like GM Syncromesh MT fluid, but I don't know how much it costs.
Now:
FattyMcGee
Jul 27, 2021 11:29 AM
JerryHughes
Jul 13, 2019 11:09 AM
1lowufo
May 26, 2019 12:43 PM
JerryHughes
Apr 10, 2019 11:33 AM
DaviT
May 4, 2005 04:44 PM
