It’s been real, it’s been fun....
Old Apr 5, 2018 | 01:51 AM
Codger01's Avatar
So long and thanks for all the fish.....I am out of the Fit family. I picked up terminally expen$ive transmission issues, and with the $$ I have dumped into the old beast in the last 7 months I cannot justify more on a dd, so it is off to the knackers yard (Car Donation Serivces...a favorite charity will get the proceeds) . I may lurk around from time to time, but will no longer be an active member.Peace out all.
Old Apr 5, 2018 | 10:36 AM
Mister Coffee's Avatar
1) MT or AT?
2) What model year?
3) How many miles on the car?
4) Are you the original owner?
Thanks.
Old Apr 5, 2018 | 01:44 PM
fitchet's Avatar
Come back and share what you get as a replacement, and how you think they ultimately compare.
Old Apr 5, 2018 | 07:54 PM
sucks to hear op. GL with ur new ride.
Old Apr 5, 2018 | 11:38 PM
Codger01's Avatar
Originally Posted by Mister Coffee
1) MT or AT?
2) What model year?
Thanks.
5sp AT
2009
127500
Yes
Old Apr 6, 2018 | 10:10 AM
upallnight's Avatar
Sure it's a trans issue and not a broken axle? A broken axle can be replaced for a couple of hundred dollars if you let a shop do it or under a 100 bucks if you do it yourself.
Old Apr 6, 2018 | 06:47 PM
Codger01's Avatar
It is a transmission issue. Has given me the CEL/Flashing D 3x times now. 1st time the shop diagnosed a solenoid B issue, but it tested ok. They changed the fluids and it appeared to be working ok. Two weeks later, same issue. I power cycled the car when I got home- the flashing D went away but the CEL did not. Unhooked the battery to see if the CEL would reset- which it did. A week later CEL/Flashing D again. Shop now says teardown ($$$) or new transmission ($$$$). Not willing to pour more $$ into this car, so the charity I am donating the car to will pick it up on Monday.
Old Apr 6, 2018 | 10:51 PM
Mainia's Avatar
That is why I would change out OEM fluid to Redline or Amsoil Signature series at 20,000 miles use an inline TransProtector filter, and change out ATF fluid every 40,000 miles after. I question if a low mile used valve body would of fixed it, and get DW-1 out of it too.
Old Apr 7, 2018 | 06:11 PM
doctordoom's Avatar
Supervillain
Bon voyage!
Old Apr 8, 2018 | 12:09 AM
GE82010's Avatar
Does it have oem mats u might sell?
Vickie Thompson
Mar 27, 2024 09:58 PM
howardmitch
Aug 4, 2017 08:02 PM
Braug
Apr 8, 2016 04:47 PM
Kristinb737
Dec 16, 2014 10:12 AM
WaterWatcher
May 4, 2005 11:16 AM
