car does not start and scanner cannot read
Old Apr 15, 2018 | 12:34 AM
Tawo's Avatar
hey guys, while driving home 1 day my honda fit died on me. first it cut off and then i started it again it drove for a few and died again. finally i started it and it drove me home but it died in the drive way and to this day it has not been able to start.
my honda fit cranks but does not start. we have check the fuel pump replaced it and no change. the relays checked, fuses checked same thing. battery is good. it was then said that it was the ecu thats the problem becuz it was hot. i got a mechanic to use a scan tool to check the problem the scanner cud not connect with the ecu. tried another ecu same result, scanner does not connect so we cannot get an idea of the problem. what do u advise that we do next because am a bit frustrated with the guessing game by the mechanics
Old May 2, 2018 | 07:26 PM
ruby22's Avatar
Hello,
Hi There please help me. After connecting my ELM 327 obd II scanner and reading the codes the car would not start or crank.It only does some ticking.
Tawo
Dec 13, 2024 05:22 PM
Tawo
Apr 19, 2018 06:48 PM
Tawo
Apr 16, 2018 04:43 PM
Tawo
Apr 15, 2018 12:34 AM
DOHCtor
61
May 2, 2011 05:18 PM
