Rear Wiper Blade Needed for 2013 Fit
Old Jun 14, 2018 | 05:09 PM
Alco RS-1's Avatar
My question has likely been asked elsewhere, but I couldn't find it.
My 2013 Fit Sport's rear wiper blade is in serious need of replacement. The rubber measures 13-3/4" Long. If I buy a typical rubber blade at an auto parts store, will it fit in the Honda arm? Is there a brand and P/N I should seek?
Honda's rear blade is held within a nice arm cover which I want to keep in place. Thanks y'all.
Old Jun 14, 2018 | 05:53 PM
vtecfit1's Avatar
76730-s2x-003 / blade, windshield wiper (350mm)$23.10
76632-s2k-004 / rubber, blade (350mm)$6.75
HONDA SELLS THEN
top is complete blade (includes part below)
bottom is just the refill (assuming you still have the metal strips that hold it in)
Old Jun 14, 2018 | 08:46 PM
Alco RS-1's Avatar
Just what I needed to know vtecfit1. Thanks a bunch!
Old Jun 22, 2018 | 09:01 AM
Alco RS-1's Avatar
I bought the rear wiper rubber blade (only) at the Honda dealer. Can someone help me with the technique to install it? The blade assembly is contained by the arm trim piece at both ends and I can't figure out how to extract anything. Thank you.
Old Jun 22, 2018 | 01:35 PM
stevenX's Avatar
You just slide out the metal rod... will post a youtube link..
Old Jun 22, 2018 | 01:51 PM
stevenX's Avatar
Old Jun 22, 2018 | 02:38 PM
Alco RS-1's Avatar
Perfect video stevenX! Job now done, no hassle. Thanks VERY much.
Old Jun 22, 2018 | 02:43 PM
stevenX's Avatar
No problem! When I was replacing mine, the rear blade was the most hassle to deal with for some reason...
Old Jun 22, 2018 | 06:20 PM
Alco RS-1's Avatar
That's true. My usual technique is to break the item THEN discover how it went together. :-)
Too, dealing with all black parts is always a challenge. It's hard to determine were one part ends and another begins!
Old Jun 24, 2018 | 10:59 AM
Alco RS-1's Avatar
Just thought I'd post two photos I took during the rear wiper blade replacement job to give an additional assist anyone who might want them.
Wiper arm in position to remove. When reinstalling, the small nubs on the inside of the blade assembly (unseen here) slide into the shallow curved grooves in the arm.
Pull blade tip and lift it out of the wiper arm to clear it of the metal stop at the end.
pip_rocks
May 14, 2025 01:20 PM
Flashesbuck
Jan 4, 2023 11:33 AM
SilverEX15
Jun 22, 2017 09:54 AM
Bill Welty
Mar 16, 2015 03:18 PM
07fitsport
13
Nov 13, 2008 06:33 PM
