Acceptable wheel offset
Old Sep 22, 2018 | 09:52 AM
stephenmarklay's Avatar
I am lurking around for some winter wheels and came across some with a 45mm offset. The stock steel are 50mm so that is a 5mm difference. The tires I will use are 175mm width so I should be nearly stock with regards to clearances.
There is always the any difference is hard on the bearings etc.
Thoughts?
Old Sep 22, 2018 | 11:00 AM
GAFIT's Avatar
Can you give us the rest of the specs? 45mm offset is generally very safe, but I'd like to see the rest of the numbers.
As in, 15x6, 16x7, etc wheel and the complete tire size. 175/??-??.
Chances are very good you are fine because that's a decent amount of offset and a very, very narrow tire.
Old Sep 22, 2018 | 01:09 PM
Thanks Gafit. I am looking at 175/65/15 for winter tires on a 5.5 wide rim. More sidewall and a tad narrower.
Old Sep 22, 2018 | 02:27 PM
GAFIT's Avatar
That all looks safe to me. You can play around with the numbers here... https://www.willtheyfit.com/index.ph...5-5&offset2=45
Old Sep 22, 2018 | 05:35 PM
Thank you again!
Adam_Melton
111
Apr 16, 2023 10:12 PM
wackyflik
May 29, 2012 09:04 AM
Chikubi
23
Mar 30, 2009 10:13 AM
sbualuba
Jan 31, 2009 02:04 PM
FireFit
Sep 13, 2006 03:38 PM
