Flashing TPMS, VSA OFF, ABS and Powersteering lights
Old Oct 15, 2018 | 08:44 PM
2Rismo2's Avatar
So I tried to install a self powered sub and used add a fuse to tap for the remote power on (Front Seat Heater* (20 A). I tapped fuse 17 listed as ACC Socket (Console*) 20A for the self powered sub since it says it only needs 10A (Kenwood KSC-SW11. Things seemed to be working, but after driving a while the TPMS, VSA OFF, ABS and Powersteering lights came on. I tried to powering off the car and back on, but the lights keep coming up. I've also tried to disconnect the positive battery terminal but they return. When you power on the car, the ABS and VSA OFF lights are illuminated, TPMS blinks for about a minute then stays constant and the powersteering light comes on. Car runs fine otherwise and I still got almost 44 MPG on the drive into work.
Another odd behavior is the push button start/stop button doesn't stop the car unless you hold it down. If you just quickly press it, it blinks about 6 times.
I made the following video to illustrate it: https://photos.app.goo.gl/4EeEAt4msWAufPLy5
I checked the surrounding fuses and nothing seems to be tripped so I'm kind of clueless what to try next. I don't have a code reader but I'll stop at the parts store to see if they can read something. Any other suggestions for things to investigate?
Old Oct 15, 2018 | 08:59 PM
2Rismo2's Avatar
When I get more time, I'm going to check Fuse Box B's fuses. I didn't mess around there, but looks like the have some EPS/ABS/VSA fuses
Old Oct 15, 2018 | 11:13 PM
ezone's Avatar
Make sure all fuses in both fuse boxes are good.
Disconnect everything you installed.
Retry.
If no improvement, REMOVE EVERYTHING you installed (and I mean leave no trace of evidence) and take it to the dealership (assuming under warranty).
Old Oct 16, 2018 | 07:18 AM
2Rismo2's Avatar
Retry.
Thank you for the response. I've disconnected the fuse taps and even disconnected the amp. I'll check the fuses and hopefully it's just that. I'm well pass my warranty so it's going to be all on me at this point.
Plumbing and electrical I typically leave to the professionals for home repair. I'm getting too old for this stuff and will probably start doing the same thing for car upgrades haha.
Old Oct 16, 2018 | 07:31 AM
2Rismo2's Avatar
I thought it actually got fixed overnight, because when I first started the car no lights came on. Before I got out of the driveway, they started coming online. It must be doing a system check and failing is my guess.
Old Oct 16, 2018 | 08:02 AM
GAFIT's Avatar
Maybe the battery ground isn't secure?
Old Oct 16, 2018 | 08:23 AM
2Rismo2's Avatar
I didn't mess with it for the sub install, but I'll double check it. I grounded near the trunk area.
Old Oct 22, 2018 | 07:22 AM
2Rismo2's Avatar
I checked all the fuses in all 3 fuse boxes and nothing was blown. Ground wire was tight. I'll stop by the auto parts store to see if they can run the code, maybe even clear out the ABS code.
Everything seems to work on the car though. I have power steering. All tires are filled up. I even tried ABS and that seems to be working as expected.
Old Nov 3, 2018 | 02:18 PM
2Rismo2's Avatar
I was able to fix this. How? I'm not sure... I got a chance to finally disconnect the full wiring harness of the sub and the trouble lights were still on. I drove around for a little. I stopped, turned off the car. Pushed start button twice without starting the car. Pushed traction control button, held it down and pushed the tpms button for a few seconds. Turned it off, then back on. Started the car and trouble lights didn't come on again. I've driven around my neighborhood and some errands with no problems. Just drive1 hour in highway, popped in a store and came out and still good to go.
I wish I could say what caused it and how to fix, but at this point I'm just glad no lights are flashing.
Old Mar 26, 2019 | 04:43 PM
evilchargerfan's Avatar
found my way here, from your post in the "What did you do to your GK Fit today?" thread
ill start with disconnecting battery, and reconnecting, and praying that it works
if that fails, ill uninstall my steering wheel, and reinstall ... and try to move slower on the 2nd go around
Old Mar 27, 2019 | 02:23 PM
disconnected battery .... turned on head lights/stomped on brakes/open doors to activate dome lights.... battery discharged
waited a few mins, reconnected the negative.
issue persists..... back to the drawing board =\
lyyre
Jan 15, 2019 01:51 PM
Crystalge9
Feb 14, 2018 05:49 AM
12BlaFit
Jul 18, 2012 11:56 AM
tkm
Jan 11, 2012 04:08 PM
vtecfit1
Car Shows, Events, and Racing
Sep 22, 2011 07:54 PM
