Car sag, rough ride....help.
Old Oct 17, 2018 | 11:40 PM
lasncohes's Avatar
Im having a problem with the front driver side. Is been acting really weird. I change The front struts, rubber boots,spring. Car has still has sag, the rough ride did improve but still there. Also there is a hissing sound.
I inspected the control arm for bend or broken nothing wrong....End links and all is fine. Could be the Control arm bushings? what else could be causing the hissing and the sag? Thanks.
Old Oct 18, 2018 | 02:09 AM
GolNat's Avatar
Why do you say it sags? Is the fender to tire distance different then the other side? Hissing when you hit a bump? All the time?
Old Oct 18, 2018 | 02:11 AM
lasncohes's Avatar
yes there is a fender difference, driver side has a narrow gap. And the hissing sound is more apparent at lower speeds.
Old Oct 18, 2018 | 08:45 AM
GAFIT's Avatar
Sounds like you have a very large cat laying on that side. And, it's MAD!
Old Oct 18, 2018 | 08:48 AM
GAFIT's Avatar
In all seriousness, what year is the Fit, how many miles, and does it have any rust?
I ask because there were some GD owners that reported shock tower separation where welds were failing under the cowl. They were all Northern cars driving on poor roads if I remember correctly.
Old Oct 18, 2018 | 03:44 PM
lasncohes's Avatar
hahaha....Its has 35k 2013 sport automatic. I check tower and no rust......it only had a small line of rust on the surface, which i really doubt it could be the cause.
Old Oct 18, 2018 | 10:10 PM
GolNat's Avatar
35K miles is not a lot so the suspension should not be worn out really. Did you just get the car the ride might be normal and you are not used to it?
As for the hissing you will need to try and replicate and try to find its source.
Does it only make the noise while moving?
Does it get louder with speed or engine RPM?
If the car is in neutral can you hear it?
Old Oct 19, 2018 | 03:59 AM
lasncohes's Avatar
The noise started a year ago, I started progressive. I sounded like a wheel bearing, I went to the dealer for inspection, They put a stereoscope one it nothing wrong. I started to think that i left the car unattended for too long, that i should had replaced the shock sooner, that the Lower control arm bearings could be damaged. I cant think of anything else that might be causing the sag.
Old Oct 19, 2018 | 09:38 AM
marmaladedad's Avatar
I LOL'd at this. My coworkers think I am crazy (more than usual).
kaikou
Oct 22, 2015 03:19 AM
JSNBRTZ
Oct 8, 2013 12:16 PM
FitSSM2k10
Aug 12, 2013 09:37 PM
Jo Jo
Mar 23, 2011 04:51 AM
get_FIT
Oct 26, 2010 12:34 AM
