Which lug nuts on Mini Cooper Steelies
Old Nov 10, 2018 | 11:06 AM
stephenmarklay's Avatar
Mini Cooper steel wheels are less $ than most other options so I am getting them but wondered if I should use the original lug nuts or get the mini lug nuts. I don’t know if the threads are the same and I don’t know if the shape of the nut on the OEM lug nuts will sit well on the Mini Steelies.
Thoughts?
Old Nov 13, 2018 | 06:02 PM
Bump on this if you can help. I ordered the wheels and tires and they will be here next week.
Old Nov 13, 2018 | 06:25 PM
evilchargerfan's Avatar
https://www.minimania.com/ss/WH_LUG_NUTS
there seems to be a strange variety of lugs that work. most appear to have a 60 degree angle to them ... perhaps an acorn/tuner type would do the truck
(now would be a good time to double check with someone that owns a mini cooper, like a friend? co worker? random person off a mini cooper forum?)
Old Nov 13, 2018 | 09:22 PM
Hootie's Avatar
I believe they're an acorn/tapered design... Not sure of the angle though. Just be sure to inspect the seats for the lug nuts before buying a set!
Also did a quick image search using a MINI specific chassis code (R50, R53, R56, etc) and I keep seeing acorn/tapered styles like those attached below. Even with that said, I'm curious if you can even use a typical 19mm similar to the factory McGaurd lug nuts or will have to downsize to a 17mm lug nut.
Old Nov 14, 2018 | 07:50 AM
This is from the Mini dealer site. WHEEL BOLT BLACK. M12X1,5. It does look similar to above. So I need to get a “nut” with this type of taper. I will do a bit more poking around.
Old Nov 14, 2018 | 07:55 AM
Thanks for this. I think there are several different lug nut styles but this link looks to cover all mini’s include the original (non-bmw) which are different.
Old Nov 14, 2018 | 08:21 AM
https://sportcompactwarehouse.com/mc...f663634f49876&
These look like they have the correct taper, size and threading…
This one was lined in another thread from 2011. The design appears to have more threads due to the area that extends past the cone mating area.
https://www.jegs.com/i/The-Wheel-Gro...395-5/10002/-1
Old Nov 14, 2018 | 08:46 AM
This is from the link above. I could not add it to my original post for some reason. Sadly they only have one set and it is another month to ship more.
Old Nov 14, 2018 | 09:12 AM
This one on amazon may be the ticket?
Amazon Amazon
Old Nov 14, 2018 | 01:03 PM
it should work
its amazon.... buy it, and try it!
Old Nov 14, 2018 | 06:23 PM
I ordered the Amazon version. I will follow up as the Mini Steel wheels are about least expensive option going.
Old Dec 16, 2018 | 05:29 PM
Our weather had been decent so I had not yet mounted the new snows yet. I checked out the lug nuts today to see how they meshed with the mini wheels and they don’t fit. The outside dimension of the lug nut thread extension will not pass through the bolt hole sadly.
I guess I need to find some without the extension part.
Old Dec 30, 2018 | 04:53 PM
Just a quick update if anyone wants to run factory Mini Cooper steel wheels. I ended up with Mcgard lugs and locks. They are longer than need and look like nipples
They do however fit fine otherwise.
hydrocynus
Jan 3, 2017 01:46 AM
fiteddy
Jun 26, 2013 04:59 PM
rocketberger
19
Nov 13, 2012 07:30 AM
pandayun
Apr 4, 2012 05:17 PM
Spyderfenix
Jan 22, 2010 04:04 PM
