Alberta fits!
I was just thinking, if you aren't dead set on OEM, weathertech part #82429 is a set of GD3 window visors. They sell them on weathertech.ca for $149.95.
Amazon.ca carries EBC brake parts! Going to upgrade to their rotors and pads this spring, so I think I found what I'm getting instead of my sway bar.
I just did my brake job done last week.
I put ATE Drilled rotors and EBC red stuff in the front And I put wagner thermoquiet brake shoes and brake drums on the rear as well as new hardwares and caliper pins. I'm still breaking in the pads and rotors (bedding if that's what they call it) no brake dust and silent braking. Good enough for my daily driving.
Damn.
These guys are already out of the visors. Sorry, Josh.
That's where I bought mine from. But I guess you are set on Mugen ones?
Honda 06-08 Fit Jazz Visor
Damn.
I'm planning to cut my front springs a little bit to even the wheel gap on the front and rear. I have lifetime warranty on my KYB from partsource 😂
Does anybody here have aftermarket steerinh wheel on their fit? If so, what Boss Hub did they use? And also is the passenger airbags and curtains will still work? I don't mind not having an airbag on my seat but i want my passengers to be safe 😂
I have an NRG hub and quick release, going to use a Works Bell U-turn harness to keep the other airbags functioning.
Just keep in mind that the Weathertech visors only go into the channels as opposed to the OEM/Mugen ones that are installed with 3M tape and clips.
i have an nrg quick release. but i might just use a generic boss hub kit that i used on my rsx before.
NRG is generic. I wouldn't be surprised if you replaced it with the same one with a different logo stamped/painted on it.
Back when I had my V6 Z24, I used a Grant hub. They don't list the Fit, but I know they have one that works. I want to say same as the older Civics, but I can't remember. They make OEM grade stuff and it doesn't cost as much as brands like Works Bell. Not knocking WB by any means, they make amazing quality parts. But you definitely pay for it.
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Works Bell U Turn Harness / Air Bag Light Fix (Male)
And Spryter is correct, NRG is already generic. My original plan was to go Works Bell everything, but then again the price is way too steep for a QR set-up. I'd rather put the money that I save for my Sparco seat and Wedge bracket.
Brakes, suspension, interior. More specifically:
Brakes:
EBC Rotors and pads
Suspension:
Spoon front sway bar
Progress rear sway bar
Cusco lower arm bar
Rigid collars
Interior:
Sparco R100 front seats
J's seat brackets
Momo Automatico leather shift knob
New steering wheel
Lord knows if I'll accomplish all that, but I'm going to try. Brakes are pretty much happening no matter what. Suspension is next. Starting with the lower arm bar because of money. Once the car is paid for, it will be easier to deal with.
Brakes:
EBC Rotors and pads
Suspension:
Cusco lower arm bar
Rigid collars
Interior:
J's seat brackets
New steering wheel
Anyone recommend good cheap brake setups? Im either gunna replace the stock ones with new stocks, or get an upgrade. Either way my pads are low and i gotta do it soon.
Also broke the 100000km barrier!
My other plans this year are to repaint the hood and get it clear braed. And maybe considering a rear RS bumper with 4th taillight, but i gotta figure out the cost and if i wanna cut my rear bumper beam.
Sorry, I meant Power Stop for my rotors:
More Information for POWER STOP JBR522XPR
More Information for POWER STOP Z231394
Installation is easy as long as the retaining screw for the rotors aren't seized or stripped. Might be a good idea to buy new ones or put anti-seize on them upon re-install.
I think i might attempt diy in the future. Its too cold now and my remaining pad is too low to wait for spring. Would love better brakes though
Is machining bad for the rotor? Ive heard mixed things about doing that.
