My car was hit by another driver and he broke the passenger side headlight and damaged the side. The car is older and we want to try and fix it up some. How expensive and difficult would it be to replace a broken headlight? I've attached pictures
any advise is welcomed
Either test your luck at a junk yard for a new assembly, or buy a new one online but it’ll probably run you a couple hundred dollars
I second the Pick and Pull junkyard for a headlight. Hey, hit a sale day and you save even more. One thing about getting a "used" one is that the wear, etc. will pretty much match the headlight on the other side of your car whereas a brand new one would stick out like a sore thumb compared to the other one. Good luck.
