RDX Key fob
Old Mar 19, 2008 | 11:08 PM
fit_2_fcuk's Avatar
Ill check this out tomorrow and let you guys know about this.
Hieu
Old Mar 20, 2008 | 12:40 AM
Mugen_Dom's Avatar
I don't think the 08 RDX fob will work as the FCC ID on the back of it is not the same as the one for the Fit. Not sure about the 07 RDX fobs as I know they are different as they didn't have memory seats that year.
Fit - OUCGBD-38OH-A
RDX - N5F0602A1A
I have both in front of me at the moment, but the 07 TL fob may work...haven't been able to confirm what the FCC ID on those are...
Old Mar 20, 2008 | 12:47 AM
Mugen_Dom's Avatar
There is also this option:
HONDA SWITCHBLADE REMOTE KEY CONVERSION CASE WOW!! - (eBay.ca item 350038348567 end time 25-Mar-08 22:39:51 EDT)
At least the transmitter will work as from the holes, it looks like ours will line up, but you would still have to get the key cut and move the immobilizer over...
Old Mar 20, 2008 | 12:55 AM
Mugen_Dom's Avatar
BTW, this is what the key looks like dismantled.
As you can see, the blade itself will not work with the other DIY guides as it's too short. The small little thing is the immobilizer chip.
Old Mar 20, 2008 | 11:37 AM
fit_2_fcuk's Avatar
Yo mugen_dom
Update us on the tl key. Im trying to figure out if it works but im not getting any luck on it.
Hieu
Old Mar 20, 2008 | 02:22 PM
Mugen_Dom's Avatar
Update!
After reading through countless TL, TSX, RDX, Accord, CRV threads, I've found the following picture:
This is an Accord key fob and if you look very closely you can see that the FCC ID is an exact match of the Fit FCC ID. That means the TL fob WILL work with the Fit, but the immobilizer chip will not (you can identify this by the letter that is stamped on the blade of the key).
So you will probably have to buy a TL fob and have it cut to match your Fit key and then take it apart and switch the immobilizer chip.
I'll be heading to an acura dealer later today to see how much they are...and if they will cut it to a honda key...
Old Mar 20, 2008 | 03:05 PM
methodbasic's Avatar
thanks mugen_dom, keep us updated. This is something i am def interested in. The TL keys were $35 or so a while back, the cheapest i've found recently was $54.
Old Mar 20, 2008 | 05:20 PM
Mugen_Dom's Avatar
No probs!
So, went to the Acura dealer today and talked to the parts guy. 07 TL fob memory seat 1 is CDN $43.07, while the memory seat 2 fob is CDN$132!!!
Ordered the key fob and he should have it by Saturday possibly Monday because of Good Friday.
He told me it would cost CDN$45 to get the key cut, but i'm going to get the fob first and make sure the keyless entry works first before doing anything else...
Old Mar 21, 2008 | 10:57 AM
Rocks A GD3's Avatar
Dude that's awesome please keep us posted with updates, and thanks for letting us know!
Old Mar 21, 2008 | 11:58 AM
yeamans17's Avatar
The process of setting up the keyless entry requires the key be in the ignition on these keys, so you'll likely have to have it cut ahead of time
Old Mar 21, 2008 | 11:18 PM
Mugen_Dom's Avatar
Yes, I know you need to have a key to turn the ignition on and off, but you do can use any key to do that.
Old Mar 22, 2008 | 12:59 AM
  #32
fit_2_fcuk's Avatar
ok i just got my switch blade fob key today. I havent had a chance to program it, but im going to go to honda tomorrow to get it program. So wish me luck.
Hieu
Old Mar 24, 2008 | 11:03 AM
  #33
rodpaine's Avatar
Hieu
How did you make out with this process?
-Rod (tired of being stabbed by Fit Dagger key!)
___________________________________
2008 5-speed Sport purchased 3/8/08
Zeta Dead Pedal, ScanGauge II
1217 miles fuel economy average - 38.74 mpg
Rods Autos Website
Old Mar 25, 2008 | 10:39 PM
  #34
so any updates? anyone get this to work?
Old Mar 26, 2008 | 12:03 AM
  #35
Mugen_Dom's Avatar
My TL fob is ready to pick up, but the dealership closes at 5 and I get off work at 4....
I'm going to see if i can get out there tomorrow...
Old Mar 26, 2008 | 01:16 AM
  #36
eagerly awaiting updates!
Old Mar 26, 2008 | 09:26 PM
  #37
Mugen_Dom's Avatar
OK, got the key fob.....but I can't find instructions on how to program it for the Fit!!
Anyone know how to do it?
Old Mar 26, 2008 | 09:54 PM
  #38
Mugen_Dom's Avatar
OK, found it out and good news and bad news.
The good news is that the TL fob works with the Fit but right now, only the Lock button works. The unlock and panic doesn't work.
I remember reading this in some of the other threads so i'll have to go back and research this a bit more.
Old Mar 26, 2008 | 10:24 PM
  #39
Mugen_Dom's Avatar
OK, even more good news but also some more bad news.
The TL Fob DOES work with the Fit. Lock, Unlock, Panic all work (you have to unlink the memory seat function in the remote for the unlock & panic to work).
But the bad news is as follows:
This is what the key looks like when you take it apart from the housing:
unfortunately, the immobilizer chip is located here in the key:
so you'll need to dismantle the fob and then dig into the plastic surrounding the key and replace the chip with the one from your fit key...
Looks like i'll be trying that this coming weekend.
Old Mar 26, 2008 | 10:49 PM
  #40
alexfree05's Avatar
so you pick a TL fob key and a honda key?
