RDX Key fob
Old Mar 26, 2008 | 11:19 PM
  #41
methodbasic's Avatar
mugen_dom,
did you get your key cut already?
do you need to switch the chip before you can program the lock, unlock, and panic buttons? If you do.... i feel the need for a DIY to be done
Old Mar 26, 2008 | 11:20 PM
  #42
Originally Posted by alexfree05
so you pick a TL fob key and a honda key?
no its just the TL key fob, it comes with a blank key that needs to be cut.
Old Mar 26, 2008 | 11:42 PM
  #43
alexfree05's Avatar
so cut the key to your honda fit's key?
and then re-program it?
thanks
Old Mar 26, 2008 | 11:51 PM
  #44
basically, yes.
you may need to replace the TL chip with the fit chip prior to programming it.
Old Mar 27, 2008 | 12:57 AM
  #45
Rocks A GD3's Avatar
Hope everything turns out well i'm excited to do this if its successful, thanks for being the first to try it out!
Old Mar 27, 2008 | 12:59 AM
  #46
alexfree05's Avatar
basically, yes.
Thanks!!
I would like to do this diy also!
Old Mar 27, 2008 | 01:03 AM
  #47
So the only thing you need the dealership to do is to cut the key? And you can program the remote TL fob to unlock, lock, etc. on your Fit by yourself? I don't understand the part where Mugen_Dom said you have to unlock the memory seat function. Lastly you would have to implant the Fit's key immobilizer into the TL's key right?
***Update***
I was reading and i think to unlock the memory seat function you just press the "Lock" and "Unlock" button as the same time until the LED blinks twice. Someone verify this?
Old Mar 27, 2008 | 02:47 AM
  #48
***Update***
Yep. You dont need a dealer to program the key, it is a series of pressing keys on the remote, and turning the key in the ignition, etc. From what i read its fairly simple. The only difficulty would be implanting the immobilizer. I cant wait for this mod
Old Mar 27, 2008 | 09:56 AM
  #49
Mugen_Dom's Avatar
FYI
I did the immobilizer transplant last night. It's not as hard as i thought. Took me about 15 minutes.
I'm going to see if i can get the key cut sometime today and if it works, then i'll do a DIY.
Cheers!
Old Mar 27, 2008 | 11:15 AM
  #50
Sweet can't wait! Thanks man!
Old Mar 27, 2008 | 01:20 PM
  #51
Mugen_Dom's Avatar
Got the key cut and it works like a charm!!!
Watch for a DIY sometime tonight (if i have time) or maybe tomorrow!
Old Mar 27, 2008 | 01:29 PM
  #52
Congrats man, ill be looking forward to this DIY.
BTW: Where's the best price to get the Key fob at? I checked on Acura Parts @ AcuraAutomotiveParts.org - Genuine Acura OEM Parts from Acura Carland and its $59.67. Best price i found so far.
Old Mar 27, 2008 | 01:40 PM
  #53
JDMchris.com's Avatar
I run THIS
Rep'd! I will do this SOON!
Old Mar 27, 2008 | 02:31 PM
  #54
hey JDMchris you wouldnt happen to have the ability to get this key fob in bulk for a discount would you?
Old Mar 27, 2008 | 02:57 PM
  #55
Good idea!
Old Mar 27, 2008 | 03:05 PM
  #56
I run THIS
i will look into it.
Old Mar 27, 2008 | 08:04 PM
  #57
SD_MR_FIT's Avatar
man this is interesting. i think ill follow this thread for the updates on the bulkness status
Old Mar 27, 2008 | 08:07 PM
  #58
Mugen_Dom's Avatar
Old Mar 27, 2008 | 11:37 PM
  #59
thanks man! you get three intranetz!
Old Apr 11, 2008 | 02:30 PM
  #60
dlong's Avatar
I would be happy with the conversion from the Base Remote with separate Key to Sport Base with embedded key. Anyone done this?
Thanks,
-d
