GD Jazz battery light / no charging
Old Jun 17, 2021 | 12:51 PM
mobby_6kl's Avatar
Exclamation GD Jazz battery light / no charging
Haven't driven the car this week and when I started today to get the AC tested and recharged before the weekend, the battery light stayed on. So of course I didn't go anywhere
  • Battery terminals were a bit loose but tightening didn't change anything
  • When running, voltage at the battery is around 12.2 or so.
  • When running, the voltage at alternator positive terminal is same as battery, i.e. 12.2 or so.
  • Edit: Also managed to confirm the black/yellow wire is 12v
I needed a 4 seat car tomorrow so I'd have to fix it before lunch or rent something else. I ordered an alternator that I should be able to pick up first thing in the morning, but is there anything else that is likely to go wrong on these cars?
Old Jun 20, 2021 | 03:05 PM
mobby_6kl's Avatar
Bumping this for resolution.
Only other potential issue I found was the ELD but it seemed fine. No time to try to diagnose obscure ECU issues so I picked up the new alternator first thing in the morning and installed it before work, which resolved the charging issue. Drove about 600km over the weekend and there were no issues with the charging or belt squealing etc.
Which is kind of expected, but I hate to throw parts at cars without properly tracking down the root cause first.
Old Jun 24, 2021 | 03:32 PM
mobby_6kl's Avatar
Just made a post with the detailed process in the project thread. It's not a bad DIY job.
https://www.fitfreak.net/forums/1st-...ml#post1461278
scootley
Dec 6, 2015 09:46 PM
blaaaackfit
Jun 4, 2013 04:41 PM
MTLian
Jan 15, 2013 02:32 PM
k3uns
Jun 13, 2012 01:00 PM
hobbes87
Oct 6, 2010 11:46 AM
