Honda Fit/Jazz GP1 (IMA) Hybrid battery cooling fan cleaning DIY tutorial
Old May 10, 2022 | 04:18 AM
Shamindra Samarakone's Avatar
in this DIY video im showing how you can clean the GP1 Hybrid Battery cooling fan also known as IPU module fan.as time goes the hybrid battery cooling fan tend to gather dust and debris may lead to faults and the inverter + the 110v battery will start heating up. cleaning the fan and the air ducts will prevent us from expensive replacements to come.having a air compressor will be helpful but if not a blower or even a vacuum with a blower can be used. for tools all you need is the standard wrench set and a "Star" Allan key set. if you are trying this make sure you don't fiddle with anything else on the hybrid battery unit as it may cause problems and also have a risk of electric shock.so please be careful.
sooznd
Jul 22, 2016 02:37 PM
Chonk
May 8, 2015 04:40 AM
CrystalFiveMT
Oct 16, 2010 09:24 AM
stevejackson
Aug 8, 2008 04:58 PM
Jeff
Sep 3, 2005 01:30 PM
