Two Ways To Prevent A/C Damage from Rocks DIY/Photos
Old Jan 29, 2013 | 12:50 PM
  #101
Triskelion's Avatar
Originally Posted by doane2u
Manxman, Triskelion, and everyone who contributed to this thread, a big thanks! You've created another project for my weekend!
You are welcome, Doane. Congratulations on being someone who follows good advice.
Old Jan 29, 2013 | 10:30 PM
  #102
doane2u's Avatar
I may have missed it.... can some one tell me what the measured size is for a mesh panel directly behind the grill opening?
I want to go looking for a material I can use and hopefully I can find something that will go in as one piece.
Thanks,
Old Jan 29, 2013 | 10:32 PM
  #103
doane2u's Avatar
Originally Posted by Red Rockit
Here ya go!
That looks great, really echos the look of the upper grill mesh!
Old Jan 29, 2013 | 11:15 PM
  #104
Texas Coyote's Avatar
Thanks,
Here is some stuff I'm considering to use..... Universal Anodized Racing Mesh Grill Grille Vents Hood 36"x11" 90cmx28cm | eBay
Old Jan 29, 2013 | 11:42 PM
  #105
doane2u's Avatar
Thanks TC: I want mine black so that would eliminate painting, but the price seems a bit high at over $40 when you figure in shipping. Will have to look around first.
Old Jan 30, 2013 | 01:03 PM
  #106
Triskelion's Avatar
The "Mr. Grille" billet aluminum overlays are worth twice the price, and he does have black anodized grilles. But here is some more material that would work well:
Universal Black Aluminum Mesh Grille Grill 12 inch x 48 Inch | eBay
The 12" X 48" size quoted in the ad is enough to protect the A/C condensers for TWO Fits. Price is really good, and it is black anodized, not painted.
Old Jan 30, 2013 | 08:50 PM
  #107
doane2u's Avatar
Yea, that looks good too. Thanks,
Old Feb 5, 2013 | 10:36 AM
  #108
doane2u's Avatar
My weekend project results
I ended up going with the $3 gutter guard aluminum mesh. I gave it a coat of Rust-Oleum semi gloss black. What ever gets put in there is going to get dinged up and I wanted something inexpensive and easy to replace. I also like the looks of it with the upper grill which it echoes the pattern of with out standing out too much. Here's the finished job... I also Plasti-dip sprayed the chrome H emblem.
I removed the top radiator cover and the upper grill assembly for easier access to the back side. (While I had the upper grille off I Plasti-coated the H emblem.)
I cut a piece of cardboard to the rough size than, holding it in place I marked with pencil from the front side where the four tabs on the rear of the bottom grill supports protrude. I cut out the holes and checked fit with the cardboard template. I than cut the wire mesh to the size of the template and cut out the tab holes and then secured it to the back using 4" black wire clamps just below the horizontal bar on each of the 4 vertical bars. The tabs also hold the mesh tightly, just don't make the holes too big.
To make it easier for anyone else wanting to do this, here are the measurements for the mesh. This is for my base model 2009 with fog lights, don't know if others are different. Thanks Triskelion/Manxman and to everyone for the ideas and information. Once you have a template, making them is a breeze.
Old Oct 24, 2013 | 02:43 AM
  #109
camivill's Avatar
I never thought this would hppen to me... but a "stupid" rock fell from a Truck, passing by a bridge here in Shanghai, China, and the freaking stone, bounced one time on the road, and "beautifully" enter thru the grill and "BAM", damaged the condensator.... spent USD200 fixing...
This DIY is a must!
Old Oct 24, 2013 | 04:00 AM
  #110
loudbang's Avatar
AH grasshopper you should have learned from your master to never ignore advice from your elders.
Sorry about your condenser.
string3599
Feb 17, 2012 02:27 PM
littleblackcar
Oct 25, 2011 10:03 PM
mary
Jul 28, 2010 08:57 PM
manxman
21
Aug 8, 2009 03:44 AM
manxman
69
Apr 21, 2009 03:00 AM
