DIY: Installation of lowering springs on 07-08 GD3
Old Apr 25, 2024 | 12:38 AM
  #161
Scratch&Dent's Avatar
It’s hard for me to tell based on those limited pictures, but my guess is that the rear would not be a true coilover with that kit. If that’s the case, then the springs would be separate from the shocks just the same as stock, and you could lower the rear by raising each corner and adjusting the spring as per the instructions.
I would recommend cutting the bump stops if you’re planning to lower the front even 1 inch.
Katsumoto
Apr 25, 2024 12:40 AM
jdmekh22
Jun 9, 2015 08:34 PM
Paulo107
Jun 11, 2014 07:37 PM
ivanh
Dec 9, 2010 12:47 PM
Raymond87
20
Dec 19, 2007 02:44 PM
