Hella Supertones in a GE8...Please help!
Old Jan 2, 2013 | 08:19 AM
  #41
Java^FiT's Avatar
Originally Posted by Spitfire
The following wiring diagram appears to indicate that the stock horn is kept "in the circuit" when Hella Supertones are installed.
Is there a reason to keep the stock horn wired-up?
I have a Fit Sport, so after installation of the Supertones I'd still like the alarm to work, and I'd like the "door lock beep" to work.
No need to keep the stock horn actually connected, just showed that to clarify that you must tie into that stock horn wire. its up to you if you want to leave it or not.
EDIT: forgot to mention the alarm and beeps for locking are managed by another horn located behind the bumper and underneath the drivers headlight so you don't have to worry about that.
Old Jan 2, 2013 | 08:48 AM
  #42
Spitfire's Avatar
Perfect, this is exactly what I needed to know.
Thanks,
S.
Old Jan 2, 2013 | 12:26 PM
  #43
Java^FiT's Avatar
Thanks,
S.
Not a problem, let us know how the install goes!
Old Jan 3, 2013 | 06:19 PM
  #44
StinklePink's Avatar
Stupid question here but......are we sure the additional relay is absolutely needed? Especially if you take out the OEM horn?
Couldn't you get by without it on the stock fuse? What is it 15A?
Old Jan 3, 2013 | 09:26 PM
  #45
Java^FiT's Avatar
Relay comes with the horns I don't see why you wouldn't want to use it or be against it. The fuse is a 20A as stated earlier in the thread
Old Jan 4, 2013 | 01:50 AM
  #46
jgpoirier's Avatar
I think he was referring to the original stock horn fuse. Which if I remember correctly is a 15A. Have read before on Subbie forums that lots of guys dont use another relay and get away fine. The only I would worry about is I have heard that some supertones have been known to draw close to 12A a piece and on your stock horn wiring you'll fry your wires. Personally I'd use the seperate relay with the new wiring supplying seperate 12V power with the 20A fuse, that way your not cooking any vehicle wiring.
Guy
Old Jan 15, 2013 | 09:20 PM
  #47
Spitfire's Avatar
The instructions that came with my Hella's called for a 16A fuse rather than a 20A. I finished my install today ... they certainly are loud!
Old May 28, 2015 | 10:21 PM
  #48
gregdeezey's Avatar
heres a pic when my install was complete
Do you have a pic with the grill in? Can you see the horns?
Old May 28, 2015 | 11:53 PM
  #49
Java^FiT's Avatar
I don't actually own my Fit anymore but from what I remember you can see them a little with the stock grill and they are a bit more pronounced with an all mesh grill like the jdp grill. Hope this helps!
Old Apr 11, 2017 | 12:25 PM
  #50
luchobucho's Avatar
Thanks
Resurrecting an old thread....
Thanks for the images. I just got a new (to me) GE8 FitSport. It's a 2012 that I scored with only 25000 miles. I've made a few enhancements in the past month since I got it.
I put in a new Kenwood Head Unit - cuz its 2017 and I wanted bluetooth and Spotify support. I ran the USB cable down to the panel next to the 12V outlet.
Also, thanks to you guys, I put in two Hella Sharptone horns. They look pretty "sharp" and sound great. I hung them off the same location as the stock horn.
Question: Anyone ever replace the stock alarm horn with a beeper (a la Toyota)? I think that would sound infinitely better.
msoulier
May 23, 2016 05:11 PM
demouser
Aug 30, 2014 10:26 PM
over40pirate
Jul 14, 2013 10:33 AM
ccaddy
May 30, 2009 10:43 PM
CMegalodon
Mar 12, 2009 02:04 AM
