headlight restoration
Old Oct 29, 2013 | 06:54 AM
fade-2-black's Avatar
Originally Posted by GD3_Wagoon
hmm... you could have a bad seal that water somehow leaked into when you were wet sanding. bake them open, remove the moisture, then reseal -- this is a good opportunity to black out your headlight housings if you're down with that look.
i remember seeing a DIY somewhere on fitfreak, just search.
GD3_Wagoon, could you possibly post the link here? I badly need the info. My driver's side lights are getting foggy from the inside that's probably causing the yellow discoloration. TIA!
Old Oct 29, 2013 | 11:15 AM
palos's Avatar
Originally Posted by kodok3ribu
since the haze appears from the inside, can anybody gives me suggestion?
Are you certain the haze wasn't always on the inside, but that you didn't see it until you cleaned/polished the outside? If you are still located in Jakarta, if your headlights aren't completely sealed, one of the air pollutants may have caused the inside hazing.
Super Mario
Jul 6, 2015 06:56 PM
txmatt
Feb 14, 2009 02:37 PM
FELIXY69
Jan 7, 2008 03:42 PM
feddup
Oct 2, 2007 07:11 PM
FikseRxSeven
Aug 19, 2006 09:45 AM
