Headlight/Dimmer Switch Removal/Replacement
Old May 20, 2013 | 03:20 PM
Degaman's Avatar
2007 Sport Fit
I have the dimmer switch ready for removal, except that the dash interferes. Is there an easy go-around besides dash or steering column removal?
Old May 21, 2013 | 01:14 AM
loudbang's Avatar
According to this only the covers need to be removed. you need to view this with Internet explorer to see the photos. Click on the small grey boxes to open the photos.
Steering Column Removal and Installation
Old May 21, 2013 | 04:16 AM
Black3sr's Avatar
Just remove the covers -
Old May 21, 2013 | 10:36 AM
Degaman's Avatar
Thanks for the input, but I have the covers removed, have the screws removed from the switch and have the connector disconnected. The switch will only come out so far before the dash enclosing the steering column interferes. Will probably take to dealership if a workaround cannot be found.
Old May 21, 2013 | 10:55 AM
Black3sr's Avatar
The lower part of the dash? If so those panels pull off as well . Just grab and yank.
Old May 23, 2013 | 04:22 PM
Degaman's Avatar
So, after speaking with a Honda tech, my fears have been confirmed. The steering column must be unbolted and dropped enough for the switch to clear the dash. They are charging me an hour labor, so the job will cost close to $100.00. Looks like this pertains to the Fit only.
Old May 23, 2013 | 05:06 PM
Black3sr's Avatar
Duh. I just realized you have an GD and I am running on about a GE8.
widg
Dec 13, 2022 02:26 AM
James Butler
Aug 15, 2018 11:49 PM
dwtaylorpdx
Jul 3, 2016 10:08 PM
hillsmagee
Jun 30, 2016 04:04 PM
rjjii1980
Oct 6, 2015 06:17 PM
