Is this Coil Pack/Valve Adjustment or a Transmission Rattle?
Old Nov 3, 2016 | 11:59 AM
  #61
inkeye's Avatar
So are these the part numbers I need if I end up doing it myself?
38900-RLC-024 - Clutch Set, Compressor
38924-RLC-014 - Coil Set, Field
38912-PE1-702 - Shim Set
38942-PWA-004 - Pulley, Idle
Thanks for all the info.
Old Nov 3, 2016 | 06:37 PM
  #62
eGadgetGeek's Avatar
The Clutch Set includes the Shims and Pulley so you only need the Clutch Set and Coil Set.
perkidddoh
Mar 25, 2018 06:31 PM
wasserball
May 3, 2017 06:02 PM
richardwhite
Sep 4, 2014 09:43 PM
geepondy
Mar 10, 2013 12:49 AM
gfrobe
Dec 19, 2012 03:58 PM
