How to get more air circulation under the hood?
Old May 16, 2008 | 05:25 PM
suketoborudo00's Avatar
Originally Posted by henryd1981
I think that came from an episode of The Simpsons.
speed holes + car hood = homer putting holes in his hood with a pick axe
first thing that came to mind as well
Old May 16, 2008 | 08:05 PM
jezzy's jazz's Avatar
do the washer trick. i have 11 on each side.
well on each bolt heh.
any pics of this, i was thinking of doin this also but wud like to c how it looks before i do it, any suggestions???
Old May 17, 2008 | 03:12 AM
kimo's Avatar
What about fender grill.
Old May 17, 2008 | 06:21 AM
jdjohnson9's Avatar
I have been wondering the same thing. I found a ram air scoop for now that will bring the temp down a couple degrees and then im gonna send my header and mani off to get coated. Here is a link to the ram air scoop so you can get an idea of what im talking about. haha. https://www.fitfreak.net/forums/gaug...n-started.html. Maybe that will help you out.
Old Jul 7, 2008 | 08:10 PM
gloryhound's Avatar
for this washer trick some of you guys talk about... where are you guys putting these washers and what size washers are they. id like to try this.
Old Jul 7, 2008 | 08:47 PM
solbrothers's Avatar
skateboard bearings
i was rocking the hood rake like 3 years ago lol
Old Jul 8, 2008 | 08:11 AM
solbrothers, any problems with heavy downpour with the raked hood???
Old Jul 8, 2008 | 11:07 AM
dewthedew's Avatar
isnt there a downside to header wrap?
Old Jul 8, 2008 | 11:27 AM
Miguelangelo's Avatar
Moisture???
Old Jul 8, 2008 | 11:50 AM
Sugarphreak's Avatar
Push My Button
There is potential for mosture to get in and rust even stainless headers, also a potential for the header to crack.
Old Jul 8, 2008 | 11:51 AM
Push My Button
Sounds like a good idea, but I don't know if a CF scoop is maybe too aggressive for styling on my car. If I was going to go that route I would probably just pick up a whole new vented hood.
Old Jul 8, 2008 | 12:27 PM
  #32
SD_MR_FIT's Avatar
i have no problems at all.
i have 11 washers so its about the same as the del sols.
heh.
i took off the weather guard on top of the hood to help it even more.
its all pros...no cons.
Old Jul 8, 2008 | 05:27 PM
  #33
excellent, must give that a go sometime...
Old Jul 14, 2008 | 10:57 AM
  #34
kimo's Avatar
Talking
In my City there is a plastic panel under the wipers that you can take off near the hood, so you can pour brake fluid, so if you leave it off it will make the hot air come out. I think Fit has the same panel.
Old Jul 14, 2008 | 02:15 PM
  #35
accordguyintake's Avatar
i think you're right! They are next to the vents that pull in air to the A/C, good find!
Old Jul 14, 2008 | 07:07 PM
  #36
ciburri's Avatar
On each side of H badge stick in wet/dry vac floor attachment and let them come out on each side of the hood latch. They fit so tightly there is no need to strap them! Under $20 at Orchards or any place selling wet/dry shop vac and accessories.
With short ram set up I observed the drop in temperature at only 10-15mph unlike OEM set up which required $45mph+. Greater temperature drop too. Works great for stop and go city driving in hot climates.
Avoid thermal wraps by any means. They are last resort option. They trap heat(exactly what they were designed to do!) and make exhaust run even hotter. On my CRX, temperatures under extreme use caused metal of the DC headers to crystallize (changed metal properties on molecular level) and crack. Imagine dipping something in liquid oxygen and hitting it with a hammer. Same deal just opposite temperature extreme. Fortunately with extreme heat crystallization, crack appeared on the weakest point of the metal - next to a weld.
Ivan
Old Jul 14, 2008 | 08:02 PM
  #37
kelsodeez's Avatar
UNBANABLE
also, when i was doing my jdm conversion, there were plastic shrouds on each side of the radiator. seems pretty restrictive. take those out and im sure it will help.
Old Jul 15, 2008 | 01:50 AM
  #38
lidoshorty02's Avatar
i did the washer trick ill post pics tmw
Old Jul 15, 2008 | 03:10 AM
  #39
doctordoom's Avatar
Supervillain
Ivan
what the?! i never heard of metal crystallizing. i thought it would just melt if it got hot enough. or vaporize even. anymore on this? i'm very interested and curious.
Old Jul 15, 2008 | 07:08 AM
  #40
i had a go with the washer, raked hood.. 3 in the back and one in the front, nothin to drastic but looks well.. must post pics up wen i get home from wrk..
one question, does this put any stress on the bonnet/hood itself cos closing it seems to be bendin it slightly i think...
