T1R Vs. Password: JDM
Old Oct 8, 2008 | 10:04 PM
  #41
kylerwho's Avatar
spoon fed
Originally Posted by vshiva
so another question, which brand should i go with?
everyone has t1r and it seems to work great.
i have a password jdm and i love it. sounds great but you sorta shoe horn it in. not a hard install though.
not to sure about the arc but im sure it will be a great piece.
i would do password jdm because you get a lightweight battery.
Old Oct 9, 2008 | 02:05 AM
  #42
vshiva's Avatar
i see, another noob question.
i am interested in installing CAI for auto tranny fit, is it going to be less power in low rpm and more power in high rpm?
Old Oct 9, 2008 | 08:32 PM
  #43
kylerwho's Avatar
spoon fed
try breathing through you nose only. then breath through only your mouth. your mouth can take in more air quicker. same thing with the intake. there is a minimum power loss at low rpm and is not noticeable but it will help the fit breath easier. so it has the potential for better mpg and better high rpm power.
Old Oct 10, 2008 | 12:12 AM
  #44
vshiva's Avatar
i see, which brand is the best should i go with for the CAI? is it injen or fujita? i am still a noob
Old Oct 10, 2008 | 01:09 AM
  #45
kylerwho's Avatar
spoon fed
both are great intakes. it just depends what you like and how much you are willing to pay. i would pick fujita.
Old Oct 10, 2008 | 01:12 AM
  #46
vshiva's Avatar
are there any reasons for picking up fujita instead of injen?
another noob question, if i installed the CAI should i upgrade my exhaust system? since i have a lot of air coming inside my engine then i should upgrade my exhaust. thats what i thought please CMIIW
tyty
Old Oct 10, 2008 | 01:20 AM
  #47
kylerwho's Avatar
spoon fed
tyty
i just personally have had good experiences with fujita. the idea of the intake is to help make the engine more efficient. the more efficient the motor runs the better mpg you will get out of it. adding an exhaust helps but is not required because you are not pushing more air into the motor but rather the motor is breathing easier.
my first mod was an intake. car ran great. then i fabbed up some headers and a cat delete. car ran even better. you really only need to upgrade the exhaust if you are running boost. the exhaust does help the engine perform more efficiently.
Old Oct 10, 2008 | 01:25 AM
  #48
vshiva's Avatar
currently i have ported and polished my engine, using drop-in filter and upgrade the header. whats next will be the best to upgrade my fit so it can run faster i am not thinking right now about going for boost
Old Oct 10, 2008 | 01:28 AM
  #49
kylerwho's Avatar
spoon fed
you ported and polished the head? i thought the ports had too thin a wall to do that.
i think intake and and t1r lightened pulley would suit you.
Old Oct 10, 2008 | 01:35 AM
  #50
vshiva's Avatar
yes i ported the head but its not extreme ported, whats the use of lightened pulley? do i need to upgrade my spark plugs as well?
Old Oct 10, 2008 | 01:41 AM
  #51
kylerwho's Avatar
spoon fed
look at aj-racing.com its under engine stuff for the gd3 helps lose moving weight. upgrading spark never hurt. im using ngk iradium(sp?) plugs. did you have a shop port it? how much was it ported?
Old Oct 10, 2008 | 01:47 AM
  #52
vshiva's Avatar
i did that porting stuff outside in US, and i am in US to get my degree. and if i convert it into dollar, the cost will be 150 bucks for porting my head and a little bit porting of my exhaust manifold. i have a picture of my old and new exhaust manifold if you want to see it i can post it.
i think i will go for the spark plugs and intake right now, time to hunt
Old Oct 10, 2008 | 01:54 AM
  #53
kylerwho's Avatar
spoon fed
do you have before and after pictures of the head?
Old Oct 10, 2008 | 01:57 AM
  #54
vshiva's Avatar
i dont, sorry but i took a picture when they were doing the porting stuff.
Old Oct 10, 2008 | 02:02 AM
  #55
kylerwho's Avatar
spoon fed
mind posting it? im very curious about p/p the head cause no one in the states is doing it.
Old Oct 10, 2008 | 02:07 AM
  #56
vshiva's Avatar
well this is the picture you requested
is that what you mean porting the head? i am afraid i might mislead you
Old Oct 10, 2008 | 02:12 AM
  #57
vshiva's Avatar
can i know why they are not doing it?
Old Oct 10, 2008 | 02:23 AM
  #58
kylerwho's Avatar
spoon fed
because people have tried and the cylinder wall is too thin and they port right into the oil or water passages or the port wall is too thin when they are done and it collapses when they drive the car.
Old Oct 10, 2008 | 02:26 AM
  #59
vshiva's Avatar
is that picture that i posted while ago considered to be porting head or not?
Old Oct 10, 2008 | 02:39 AM
  #60
kylerwho's Avatar
spoon fed
it looks like the mechanic in the picture is cleaning the combustion bowl. im talking about opening the intake and exhaust ports that are on the side of the head. if you took your exhaust manifold off and stuck your finger in the backside of the engine. those are the ports im talking about. where they ported too?
