T1R Vs. Password: JDM
Old Oct 10, 2008 | 11:56 AM
  #61
vshiva's Avatar
Originally Posted by kylerwho
it looks like the mechanic in the picture is cleaning the combustion bowl. im talking about opening the intake and exhaust ports that are on the side of the head. if you took your exhaust manifold off and stuck your finger in the backside of the engine. those are the ports im talking about. where they ported too?
i am not really sure all i know is that he's cleaning the combustion bowl and did something to that thing. he mentioned to me that he's doing the 3 angle valve porting
Old Oct 10, 2008 | 10:00 PM
  #62
kylerwho's Avatar
spoon fed
notice a big differance?
Old Oct 11, 2008 | 01:14 AM
  #63
vshiva's Avatar
i notice a big difference when i drove it. the kickdown is responsive, a lot power coming out in high rpm. i did the porting stuff and change the header at the same time. that would make a big difference i guess.
you mentioned about porting head, do you mean the cylinder head? if i am not mistaken if we port the cylinder head it would make the engine compression higher, am i right?
Old Oct 11, 2008 | 02:03 AM
  #64
kylerwho's Avatar
spoon fed
it would make compression higher if milled the head down. imagine laying the head on the table with the combustion chamber facing up. then taking a file and shaving over the surface of the head. this makes the combustion chamber smaller and raises compression. i want to know if the intake port in the side of the head leading to the combustion chamber has been ported open bigger than factory size? its the passage way that leads to the valve.
Old Oct 11, 2008 | 02:11 AM
  #65
vshiva's Avatar
i heard from my friend while ago, he told me that his friend did that porting stuff. he made the hole from the intake and fuel bigger and exhaust hole bigger too. i hope i explained it well, he did extreme port to compete in drag race.
Old Oct 11, 2008 | 02:12 AM
  #66
kylerwho's Avatar
spoon fed
was it on a fit though? the L15a has some pretty thin sidewalls in the ports.
Old Oct 11, 2008 | 02:21 AM
  #67
vshiva's Avatar
yes it is, auto tranny fit. i see i just knew that L15A has thin sidewalls.
my friend did some heavy mods i guess. he changed cam + adjustable cam gear, using forged piston connecting rods, rebalanced crankshaft, using stand alone ecu, adding some extra injector, coilover, big brake kit. i dont know how much it cost him right now to build that fit
Old Oct 11, 2008 | 02:23 AM
  #68
kylerwho's Avatar
spoon fed
what cam and adjustable cam gear did he use? who makes the forged internals?
Old Oct 11, 2008 | 02:26 AM
  #69
vshiva's Avatar
i might need to ask him what kind of cam he use. is it increase the engine horsepower if we use a higher degree or better cam?
Old Oct 11, 2008 | 02:28 AM
  #70
kylerwho's Avatar
spoon fed
currently no one makes an adjustable cam gear or cam for the l15a.
Old Oct 11, 2008 | 02:31 AM
  #71
vshiva's Avatar
will ask him about the mods that he have. give me time to ask him.
what is the top speed of fit exactly? is it somewhat 110mph?
Old Oct 11, 2008 | 02:34 AM
  #72
kylerwho's Avatar
spoon fed
governed at 115.
Old Oct 17, 2008 | 07:28 AM
  #73
jkf1985's Avatar
So i emailed ARC and the guy said that they dont have any plans to make an intake for the FIT at ths time but if alot more ppl request it then there is a good chance that they will put on in the works. So come on guys let them know we want one!!!
Old Oct 20, 2008 | 01:46 AM
  #74
qbmurderer13's Avatar
ARC is garbage. I used to own an S2000 and theres tons of dynos that show about a 5whp loss with it. Call it the "hot air intake". And with the tiny room in the engine bay im sure the box will most likely be right next to the header and radiator. They do that with all their intakes... They do look nice though.
Im probably going with password. 1 or 6 horsepower I wont tell the difference. Plus $40 more bucks I get the lightweight battery and relocator. Plus the filter sits deeper in the fender which will probably get cooler air than the T1R will.
Old Oct 20, 2008 | 11:11 AM
  #75
Stevens24's Avatar
While I am a big fan of T1R and have there coils I will probably get the Password simply from the dynos on there site you gains about the same and it seems like a better value.
Kyler how is the quality of there carbon??
Old Nov 3, 2008 | 01:28 AM
  #76
da9r00d's Avatar
I have the PWJDM intake and i love it, the only down side to that intake is the battery relocation, but PWJDM supplied a kit with everything.
Old Nov 3, 2008 | 01:31 AM
  #77
Wish they made those for the 09's. Thats the same setup I want.
Old Dec 9, 2008 | 07:25 PM
  #78
Im|Inside|Fit's Avatar
OMGOSH!!! that is sick =DDD i love your intake i have the same =) im planning on getting the Carbon fiber cover but too much =( but well see =)
jsut get the PW JDM intake i jstu got mines and man i love it! the sound is awesome and the look jsut trip the crap out of people =P heres some pictures =)
and video =D PW JDM with unbolt muffler =P
MVI_0012.flv - Video - Photobucket - Video and Image Hosting
Old Dec 14, 2008 | 05:03 AM
  #79
dkang2's Avatar
carbon fiber CAI
Are there any CAIs that are Carbon fiber??
There is the Tsuchinoko CAI made of carbon fiber that I am considering...its close to $800 for an intake though.....
Best results? Apparently.
I just don't know if the 07/08 intake will fit into my 09 Fit Sport. If anyone can lecture me on that one that will be great.
Old Dec 14, 2008 | 01:36 PM
  #80
kylerwho's Avatar
spoon fed
the 07/08 intakes will not fit on the 09 fits. the engine compartment is built differant so you would need differant angles on the intake. PRM is developing an 09 intake so jut wait for them. the Tsuchinoko CAI is the j's racing one right?
Cat
Jan 28, 2010 08:31 PM
silverbulletfit
Nov 16, 2008 04:41 PM
ezekiel_771
May 14, 2008 01:25 PM
Sam Misled
14
May 4, 2008 12:51 PM
garciabe
Sep 12, 2007 10:33 PM
