Mfactory LSD Installed
Old Dec 2, 2008 | 11:38 PM
MFactory's Avatar
Just a quick update to say the FIT LSD's are now in stock
Old Dec 3, 2008 | 01:49 PM
JDMchris.com's Avatar
I run THIS
Go out and get them! Best Handling mod you can buy!
Old Dec 3, 2008 | 02:24 PM
dewthedew's Avatar
I will be getting once after i get my wheels/tires next month.
Old Dec 3, 2008 | 03:08 PM
GD3-Fit's Avatar
I <3 SPOON
i'm curious to see how these perform in an autox/track environment
LSD/15s w/ sticky tires
vs.
LSD/15s w/ sticky tires/coilovers
-Ricky
Old Dec 3, 2008 | 03:30 PM
dewthedew's Avatar
how much do you guy think it will cost to get this installed at a shop
Old Dec 4, 2008 | 01:37 AM
spoonek4's Avatar
And definitely one of the best addition to help power transfer to the ground! PLUS it doesn't require expensive fluid so that keeps the maintenance cost lower.
Old Dec 4, 2008 | 09:29 AM
Previc93's Avatar
i cant wait to get this!!!
Old Dec 5, 2008 | 11:46 PM
spoonek4's Avatar
Can I say the LSD is like a mechanical traction control which helps u to accelerate but at the same time not slowing down your wheels?
Old Dec 7, 2008 | 02:49 AM
dank24's Avatar
I am picking up a LSD from them with my next paycheck.
So when I replace the clutch and flywheel, I will do this all at once.
Old Dec 7, 2008 | 03:14 PM
spoonek4's Avatar
Try to get the Mfactory 4.7final gear set installed at the same time while u install the LSD. Going uphill & carrying passenger with my car isn't painful ANYMORE! Especially if some of u who's got catback or even header back exhaust & feels like the 5th gear became useless in city, the bigger final gear will definitely help on getting response back too.
Old Dec 7, 2008 | 04:15 PM
dank24's Avatar
I was thinking about getting the final gear, but I dunno. I travel about 100 miles a day. mostly highway, so it might kick my ass if I get that. Plus I am gonna boost this winter.
Old Dec 7, 2008 | 06:44 PM
  #32
spoonek4's Avatar
I see. I did 3 tanks of gas on my car already after everything installed. So far the gas mileage is the same if not better. I just didn't have to stomp on the throttle anymore going around town & on the way to & from work merging on to highway.
Old Dec 7, 2008 | 09:50 PM
  #33
SHG_Mike's Avatar
what are your cruising RPM's?
edit: i did the math not bad... about 5mph difference at 3grand
stock 3k = 64mph
4.7 3k = 59mph
Old Dec 7, 2008 | 11:08 PM
  #34
dewthedew's Avatar
how would the 4.7 final gear work out with boost? even more awesome? spoonek4 you need to post some vids
Old Dec 7, 2008 | 11:10 PM
  #35
spoonek4's Avatar
Yeah I will try to go take some videos very soon!
Old Dec 8, 2008 | 10:16 AM
  #36
GD3-Fit's Avatar
I <3 SPOON
subscribed for interest in vids
Old Dec 10, 2008 | 06:00 PM
  #37
azkikersfit's Avatar
is this a 1.5 LSD ?
Old Dec 11, 2008 | 02:30 AM
  #38
spoonek4's Avatar
Yes this LSD fit in L15A 1500cc motor.....
Old Dec 11, 2008 | 02:39 AM
  #39
kylerwho's Avatar
spoon fed
lsd for the gd3 should explain it all.
Old Dec 11, 2008 | 02:43 AM
  #40
MFactory's Avatar
It was designed for the L15A, but should fit the L13A as well (need to confirm)
