Mfactory LSD Installed
I recommend to replace the differential carrier bearings also.
I will look up the link of that website I used before or post up the part# later on.
the part number is 91005-PPS-003
its number 6 here Cart Contents Honda Parts at HondaPartsDeals.com: Honda Accessory, Honda Car Parts, Honda Auto Parts, Honda Accord Parts
this should explain it Detailed description on how the Quaife Automatic Torque Biasing Differential functions
Here are the part# of the stuff u guys needed:
41312-PL3-B00 Speedometer Drive Gear
91005-PPS-003 Differential Carrier Bearings x 2
Here are the part# of the shims if u like to do that part too....
San Leandro Honda Online Parts
With the bigger final drive I can stay in higher gear more & still be able to cruise along without downshifting all the times(less wheel spin). And the limited slip differential helped pull me out of trouble many times especially when I turn & one of the wheel hit a lil ice patch around the corner. The other wheel with traction can get me back into the right direction without problem.
Of coz, I drove quite a bit slower than I usually do under such icy & slushy condition. AWD, LSD, TCS etc ain't gonna help u all the time if u drive like an idiot anyway.
