The Official Normally-Aspirated Thread....(techniques/parts/troubleshooting etc.)
Old Mar 30, 2010 | 10:25 PM
  #101
socalsmirff's Avatar
we do what we can with what we have. all you can do is bolt ons and some tranny work if you got the cash the. i have noticed alot since all the work i have done on my car. all bolt ons and bolt ins. but way different than stock. esspecially after the pullies, clutch and ripping out the inside of the car. but not many willing to do that to their car.
Old Apr 5, 2010 | 11:06 PM
  #102
Sugarphreak's Avatar
Push My Button
Cool to see this thread still going... this motor has got to be one of the stingiest motors I have ever come across for bolt on power.
I should really throw mine on another dyno to see how it does... not that I didn't try half a dozen shops last year... stupid Calgary.
Old Apr 17, 2010 | 03:15 PM
  #103
buttersandpaper's Avatar
This forum seems interesting, I want to go na as long as I can til like this motor goes, (which seems to be a long time form now.)
Old Apr 22, 2010 | 10:18 AM
  #104
Tiu's Avatar
Tiu
what gapping do i need on the spark plug?
Originally Posted by DOHCtor
On the 16 valves L15A, IK22 plugs (or IK20) provides better power because they are shorter then the stockers. Unfortunately, i can't say if stock plugs are limiting power for the 8 valves I-dsi engine!
As for IK20 plugs Vs. IK22... You should'nt feel more power with IK22 plugs as it's only the plug heat range!! For a near stock N\A engine, i think IK20 plugs should be better suited but i didn't tested 'em personately!!
Marko!
Old Apr 25, 2010 | 11:00 PM
  #105
grtpumpkin's Avatar
Another important thing to consider when tuning the L15 is that it was originally concieved for thrift, not sport. The power that is there with bolt ons needs to be accessed. Adding a throttle controller to get around the OE spec thrift programming language can make a big difference in the perceived power gained from bolt ons. That and realize that 5-10 HP is pretty big when you figure that you only had 100 to begin with LOL......
Old Apr 26, 2010 | 09:56 PM
  #106
Kurse's Avatar
Unorthodox Racing Pulley on a M\T Car! Expect a little less on a A\T Fit! As for the CVT, i really dont know (don't see!?) why it would mess up!
Marko!!
Its not a good idea to change the pulley, the oem crank pulley itself is a harmonic damper, it absorbs shock & vibration.
Old Apr 27, 2010 | 04:46 AM
  #107
jazzista's Avatar
Question Manage and optimize ignition timing
Sorry for my "newbyness",
I am NA, AFAIK w/o going FI "sw" tuning is essentially advance timing. I thought that AEM F/IC would tick the bill, until I found it can only delay timing (marketing, oh marketing).
Are you aware of any other possible AEM solution? AFAIK Greddy Ultimate can advance timing but it's more expensive and doesn't have all the features sported by AEM, plus it needs special harnesses and sw not included...
TIA,
Old Apr 27, 2010 | 04:27 PM
  #108
grtpumpkin's Avatar
Be careful when fiddling with timing, you really should have some supporting mods before going that route. Just advancing timing won't really net much without at least a modest bump in compression/intake/exhaust work.
Old Apr 28, 2010 | 06:15 AM
  #109
jazzista's Avatar
Hmm, ok any good reading in order to learn? How would local tuners be able to offer +7Hp and +9Nm, dyno proven, on the plain 1.2 with standard hw, i.e. just sw???
Old Apr 28, 2010 | 05:16 PM
  #110
grtpumpkin's Avatar
I'm not sure what you mean by "hw" and "sw" forgive me. +7hp sounds reasonable for a timing bump in addition to existing mods. Were those numbers generated solely by advancing timing? If so, that is damned impressive.....
Old Apr 28, 2010 | 05:21 PM
  #111
Gbaby2089's Avatar
umm has anyone changed the cam on their fit to a more aggressive set-up? i feel like that might help a lil
Old Apr 28, 2010 | 06:19 PM
  #112
Kurse's Avatar
it dont have good cam yet for the fit.
dont touch to the catcam!
Old Apr 28, 2010 | 09:47 PM
  #113
DOHCtor's Avatar
My bet...
''SW'' - SoftWare
''HW'' - HardWare
Marko!
Old Apr 29, 2010 | 02:45 AM
  #114
jazzista's Avatar
Lol, yes Marko! you won, sorry for my bad jargon.
The link of the tuner I was referring to is: ... DIGITAL MOTOR ... © 2004 by roberto.luini@tin.it ..., then select CATALOGO, then Honda Jazz. They have a good reputation here, as they are supposed not to "inflate" figures. I've asked and they are open to tune also on existing mods.
If I don't find a cheaper DIY option (greddy seems more expensive, AEM F/IC would be fine only if going FI), I would try them after hardware mods.
Ciao,
Old May 10, 2010 | 11:15 PM
  #115
FELIXY69's Avatar
Some of the best mods that can be done with a noticeable difference are a LSD, CLutch and lightened flywheel. And to one up a lower final drive.
i disagree..the best mod with noticeable difference is throttle controller!
i love mine !
Old May 11, 2010 | 03:55 PM
  #116
grtpumpkin's Avatar
Pure bang for the buck i have to agree with Felixy. The TC "wakes up" the L15, most noticeably in higher gears. Although the light flywheel and final drive would have the same effect they cost quite a bit more.
Old May 11, 2010 | 08:54 PM
  #117
im the fit's Avatar
The fit is capable of 117hp and 117tq! I think with a little more time I could have made 120hp N/A.
Old May 11, 2010 | 08:57 PM
  #118
dewthedew's Avatar
Im highest hp n/a fit
Old May 11, 2010 | 09:40 PM
  #119
DOHCtor's Avatar
On a V8 or a L6 i would tend to agree... But most abused Nissan 4 cyl. (Except KA series!) will need a Underdrive Pulley to slow down the Water pump and reduce coolant cavitation at higher RPM's... Some DSM Power Steering can also loose assistance at Higher Revs without a pulley because it whips oil instead of pumping it properly... I personately never had a single problem on any car with a pulley (Neons and my Civic!) so i don't know why i would have problems on a Fit... the L15A cranks are so short!!
But as for the ''Best Bang for the bucs'' thingie, i would say spark plugs.... 40$ for 2 - 3 HP is near 10$\1Hp.... What a bargain!!
Marko!!
Old May 11, 2010 | 09:50 PM
  #120
Kurse's Avatar
read.. READ
"the oem crank pulley itself is a harmonic damper, it absorbs shock & vibration."
