The Official Normally-Aspirated Thread....(techniques/parts/troubleshooting etc.)
Old May 13, 2010 | 12:50 PM
  #121
wdb's Avatar
wdb
Originally Posted by grtpumpkin
Be careful when fiddling with timing, you really should have some supporting mods before going that route. Just advancing timing won't really net much without at least a modest bump in compression/intake/exhaust work.
A really easy and relatively cheap way to 'advance' timing is to use higher octane fuel. There is a thread by dameone (I think that is his handle) detailing spark advance using 87 octane vs 93 octane, and the 93 showed considerably more spark advance.
In a nutshell: higher octane fuel lets the ECU reach its max potential.
Old May 13, 2010 | 03:22 PM
  #122
apexanimal's Avatar
^ if only it were that easy...
the pcm needs to advance timing quite a bit in order for the higher octane fuel to properly burn...
higher octance = slower burn = more advance timing to achieve the same burn timing...
you're not really increasing the power by going to a higher octane, you're just spending more money on a gas that your car really wasn't designed for...
now, as gtr said, if you were to do some other work, then you'd need higher octane to fight off predetonation and keep everything where it needs to be...
Old May 13, 2010 | 08:52 PM
  #123
chrisakasparky's Avatar
with the crank on the l15a being short, i'd imagine that'd mean the the resonant frequency would be a lot higher than the motor would be revving to, therefore an underweight crank pulley wouldnt be doing as much duty as far as harmonic balancing.
any engineers in the crowd?
Old May 20, 2010 | 11:03 PM
  #124
DOHCtor's Avatar
Originally Posted by Kurse
read.. READ
"the oem crank pulley itself is a harmonic damper, it absorbs shock & vibration."
Don't worry, i've read a lot on the subject!!
MotoIQ wrote: From a lot of experience building actual racing engines, building winning racecars and building winning and reliable race cars I can tell you that a solid hub underdrive pulley is not likely to cause engine failure in a modern mildly modified 4 cylinder engine.
My qualifications are that I was an engineer at TRD many years ago, I was an OEM engineer at Nissan spending the last several years working on the Nismo project and am now a motorsports engineering consultant. I have been an automotive and motorsports engineer for 20 years. I also happen to be a consultant for the Jackson Dawson team.
On a relatively under stressed near stock motor like the TC with bolt ons or low amounts of boost like what we will be running and I suspect what most of the people on this forum probably run, an underdrive pulley will not have any life threatening consequences for your motors. The factory pulley with a twin ring damper is primarily for wide band NVH (noise vibration harshness) suppression from the engine and driveline. Removing the damper and replacing it with a solid hub underdrive pulley will cause additional NVH but not harm the engine.
The engineering reasons are that an inline 4 cylinder engine has a short stiff strong crank with a relatively high natural frequency. The dangerous second harmonic that can cause damage occurs at an rpm that this sort of engine will never see, in the area of 9500 rpm.
Now the stock harmonic damper is not tuned for attenuation at this sort of rpm either so the argument is somewhat of a moot point.
Now 4 cylinders that are pushing the limit with lots of revs, wimpy cranks, super long strokes, lots of boost and dwelling in the upper rpm ranges for long periods of time can benefit from a damper designed to deal with this sort of operation but our engine is not like this due to rules contraints and probably very few people with this motor on this forum push the envelope that hard.
The tC engine has a strong and stiff bottom end that is overbuilt if anything for our intended use. It has an internally balanced crankshaft, It has a chain driven oil pump which is less like to break due to torsional vibration. Nothing is going to happen, not even in our road raced tC. Road racing is much more punishing on an engine than other motorsports. The engine is subjected to run times lasting anywhere from 20 to 45 minutes with the engine always in the upper ranges of its rpm limit. One race weekend is the equivelent of hundreds of 1/4 mile passes.
Some engines like the Nissan SR20 have to have an underdrive pulley to live at all under race conditions as the water pump cavitates at a low rpm. All SE-R Cup cars and probably most professional drift S chassis cars run an underdrive pulley. I can tell you that SE-R Cup cars are very relaible with engines lasting several seasons sometimes. The one in my car has lasted about 2.5 seasons and is still going strong. My personal 529 whp turbo SE-R has an underdrive pulley. I don't know of an SR engine that has failed due to a pulley. I know several guys that have had them for 200,000 miles.
The same goes for the VG, VQ, QR and GA engines. Many World Challenge race cars use under drive pulleys.
Is an underdrive pulley harmless to all engines? No it is not. Inline six cylinders when modified way past the simple bolt on stages will probably have problems. These engines reach critical harmonics at lower rpm due to the length of the crankshaft, this is in the 7500 rpm range, an rpm often reached by a performance engine. Now a BPU Supra or other mildly modded inline six will most likely be fine but one subjected to high rpm for long periods of time with lots of boost will probably suffer. In this case , the stock damper is probably not adequate either. In my experience with I-6 Nissan RB engines the oil pump inner gear cracks first due to crank whip. For serious I-6 motors I use ATI or Fisher dampers. Crazy stroked out B series Honda motors with strokes approaching 100 mm will also crack their oil pump gears and racing Nissan KA motors crack blocks. These motors need to have the revs limited, dry sumps and other special prep to deal with vibration in extreme full race use in very highly modifed form. American V8 engines ARE often externally balanced and it is critical not to use a solid hub pulley not designed for this application or damage to the engine will result.
Our tC engine and most people's here have motors that do not fall into the above category. Rest assured that your engine will not blow up and die or have a reduced life in street and even racing use with these parts. Will you notice more noise from the drive train and front end accessories, yes possibly.
I would bet that every "expert" that tells you otherwise here has little personal practical experience with the subject.
From Mike Kojima
There is some controversy about the pulleys, as they are not equipped with the harmonic balancer that the stock pulley has. We feel the risk of removing the balancer on certain engines is not really a risk. Inline, four-cylinder engines for the most part have short, stiff crankshafts. These do not need a balancer as much, because of their high natural frequency. Engines with long, whip-like cranks, like inline six-cylinders, need balancers to prevent failure, but most four cylinders do fine without them.
Nissan four cylinders, with the exception of the long stroke, vibration-prone KA24, can do fine without a balancer. We have had underdrive pulleys on many SR20 engines, some with more than 1,000 track miles, with no problem whatsoever. Nissan four cylinders are also internally balanced, which reduces the need for a harmonic balancer. Many cheaper engines, on the other hand, need to have a built-in imbalance on the pulley to make up for a lack of an internal counterweight. Like the SR20 engine, the GA16 engine actually felt smoother and revved more freely with the underdrive pulley installed.
Marko!!
Old May 21, 2010 | 07:41 AM
  #125
Kurse's Avatar
It only talk about toyota and nissan motor..
Old May 21, 2010 | 09:02 AM
  #126
jazzista's Avatar
Yes but logic does apply as well.
Old May 21, 2010 | 01:04 PM
  #127
Kurse's Avatar
Yes but its not there for nothing.
Old May 24, 2010 | 04:04 AM
  #128
jazzista's Avatar
Yes but, should it be optimized, I guess it should be matched to each available engine (1.5, 1.4, 1.2) but this doesn't seem the case... besides I guess the manufacturer would easily prefer to emphasize a slow smoothness towards free revving.
Same would apply to flywheel sizing, IMHO. I will report in a few days: a set of pulleys and a flywheel wait to be installed.
Old Jun 2, 2010 | 04:03 PM
  #129
jazzista's Avatar
Talking
Hi,
as a short followup, today I just had the idle learning procedure with new flywheel and pulleys (and other mods). I had a very very short test (less than 200m I beleive) but the car seemed much more responsive with bog standard air intake and a filter which cries to be exchanged.
Ciao,
Stefano
Old Jul 2, 2014 | 12:02 PM
  #130
victorgarage's Avatar
adjusting valve clearance is very powerfull to me
Old Jul 2, 2014 | 12:17 PM
  #131
jazzista's Avatar
May you elaborate a bit more?
Thanks a lot.
Greasyman
16
Dec 2, 2014 08:39 PM
ZaxMan
Jan 11, 2014 01:27 PM
Spooling
40
Nov 11, 2008 02:28 PM
one bad dx
26
Sep 26, 2008 12:58 PM
Brad_again
Mar 31, 2007 02:07 AM
