Blitz Throttle Controller INSTALLED + DIY
Old Nov 10, 2009 | 01:32 AM
Scratch&Dent's Avatar
macbuddy:
That's weird...yours really must be quirky. I've never had that happen. However, I've noticed that the power button is pretty easy to press. Mine isn't secured; I keep it in the little cubby below the fuses, and once in a while, when I put it back in there after turning it on, the power button gets pressed again.
I don't know how yours is set up, though.
Old Nov 7, 2010 | 05:22 PM
overheatedfit's Avatar
mine turns off now and then... then my car idles like i when i press the gass it wont hardly go then a check engine light comes on...
i have to turn off and the car back on again to get it to be normal
loose wire i assume what can i do to fix it
Old Nov 7, 2010 | 06:06 PM
Itsslow's Avatar
To those blitz tc users does it actually make the car quicker to 60? Even by at least a cunt hair!?!
Old Nov 7, 2010 | 08:47 PM
@overheatedfit
Sounds bad. Try removing/reinstalling?
@Itsslow
Yes. I don't know by how much, but yes. Maybe 0.5-0.8 second, tops.
Old Nov 8, 2010 | 03:49 AM
macbuddy's Avatar
Originally Posted by Scratch&Dent
macbuddy:
That's weird...yours really must be quirky. I've never had that happen...
Hey Scratch&Dent, I finally figured out why my BLITZ was acting all Schizo! I found a loose connection on the motherboard. I was able to fix the problem by re-soldering the "hairline" cracks on the MB that were securing the "wiring harness connector."
If you are interested in reading about the whole ordeal, check out my thread:
Stuck in 4th gear...BLITZ TC?
The actual "fix" is discussed in posts #13 and #15
Old Nov 8, 2010 | 12:14 PM
Thanks for posting here. I disassembled mine when I got it, just to see what's inside. (I mixed up the buttons the first time, too.) Good to know what might be waiting for me. I have had it make a weird high pitched sound once or twice, but nothing serious...yet.
Old Nov 8, 2010 | 12:56 PM
macbuddy's Avatar
...weird high pitched sound
Yeah, I have heard that "high pitched" sound several times as well. The first time I heard it, I thought it sounded like a small, high revving electric motor of some sort. I never figured out what caused it, but since re-soldering, the sound has not returned.
FYI, I believe the problem(s) all started when I accidently caught the display unit with my knee, and inadvertently pulled on the cord while exiting the car.
Old Nov 13, 2010 | 07:58 PM
lidoshorty02's Avatar
This has happen to me abt a year and a half ago. it would rev up and then the car would go into limp mode. i took the whole TC out and never had the problem again. Looks like it could be fixed though, thanks for ur post
Old Feb 1, 2011 | 11:13 PM
xalx02's Avatar
What website did you TC owners buy from?
Old Feb 2, 2011 | 01:26 AM
macbuddy's Avatar
The Fix...
Yes, I was able to fix the problem by re-soldering some of the pins on the motherboard. Some of the connections had hairline fractures. I posted a thread at HondaFitForums:
Stuck in 4th gear...Blitz TC?
If you are interested, description of the fix starts at post #13, detailed photos are shown in post #15.
I got mine through a group buy right here at Fitfreak.net
drmwgn
Sep 2, 2018 10:58 PM
revd34
Jan 20, 2014 04:49 PM
modfit669
Dec 27, 2009 03:24 AM
FELIXY69
Nov 16, 2009 11:28 AM
da9r00d
Jul 21, 2009 01:24 AM
