When is it time for an injector upgrade?
Old Feb 1, 2010 | 01:52 AM
evo9tofit?'s Avatar
Ok so I'm gonna hold off on boost for now and pick up a track car instead.. But I'm gonna mod the fit a little more first. Currently the car has a cold air, DC header, axle back exhaust and irridium Ik22 plugs. I just ordered a cat delete and should be gettin the weapon r intake manifold within the month. So with these mods is it time for bigger injectors and tunning or should I still be good
Old Feb 1, 2010 | 02:04 AM
555sexydrive's Avatar
Only way to really know is if you can see what duty cycle the injectors are running at with what you have. On that note, with what you have, most likely not at all necessary as your injectors might hit upwards of 90%, but I doubt even that high.
Old Feb 1, 2010 | 06:07 AM
JamesBizzle's Avatar
You'll be fine with the the stock injectors... upgrade them when you decide to boost the motor
Maty J
Jul 4, 2013 09:06 AM
DOHCtor
43
Dec 20, 2011 12:18 AM
jjboyes06
Nov 19, 2010 10:30 PM
evo9tofit?
Jan 12, 2010 08:07 PM
AZfitsport
Apr 30, 2007 04:24 AM
