fuel cut at 3750 rpm
Old Apr 2, 2010 | 05:41 PM
Previc93's Avatar
so i installed a greddy turbo kit on my fit and as i went for the first test drive around the block the cel came on and the car fuel cuts at around 3750 rpms. totally doesnt feel safe. i pulled a code and i got p2649. vtec solenoid high voltage. has any one had this problem when installing a turbo kit??? my car is an 07 and has 55k miles on it.
Old Apr 2, 2010 | 05:48 PM
B1str0's Avatar
RubberBabyBuggyBumpers
car is in limp mode.. reset the ecu
Old Apr 2, 2010 | 05:54 PM
Previc93's Avatar
is that like clearing the code cause i cleared the code when i checked it and it instantly came back on.
Old Apr 12, 2010 | 10:15 AM
NIGHTHAWKSI's Avatar
check your wiring and switch settingsin the emanage. definatly a install/setup issue.
Comax2
Jun 1, 2016 04:26 PM
Kevinbautista9
Feb 27, 2016 03:38 PM
Previc93
Apr 3, 2010 09:54 PM
FELIXY69
Jan 8, 2009 06:06 PM
jbourgeois
May 4, 2005 11:16 AM
