GE8 big bore throttle body question
Old Jul 29, 2010 | 11:51 PM
555sexydrive's Avatar
Originally Posted by mkchiu
It's more like 107% assuming that 44mm air filter box opening is the smallest cross section. Assuming those Neon TB restriction results are the same as on the USDM Fit (that is same area shaft and blade), then 44mm allows about 193 cfm.
1.5L ~= 91.5 ci
@100%: 6800*91.5*0.5/1728=180 cfm
@110%: 180*1.1=198 cfm
193/180 ~= 107%
Or more like 228% at the opening if the USDM GE8 Fit TB is 63mm (~2.5in). Although there are posts indicating 2.75 in. Assuming those Neon TB restriction results are the same as on the USDM Fit (that is same area shaft and blade), then 63mm allows about 410 cfm.
410/180 ~= 228%
I'm not using the stock airbox so that 44mm opening doesn't come into play. Also the GE in the US is using a bigger TB than the JDM model? I ask because J's bored throttle body is 60mm ID at the opening and 52mm at the butterfly and I believe stock is 49 or 50mm butterfly and 57 or 58 at the opening. I should go find some calipers and measure the TB opening or just crudely do it with a metric ruler.
Old Jul 30, 2010 | 05:00 PM
apexanimal's Avatar
does all of this assume that the intake air is at the atmospheric pressure the car is at? that is that there isn't a pressure drop or increase from where the air is being ducted from?
Old Jul 30, 2010 | 08:12 PM
mkchiu's Avatar
I've seen multiple posts here that say 2.5 & 2.75 in (outer diameter maybe?), but I just opened my USDM GE8. Without taking out the battery to get the the air filter housing, etc out, I measured about 57mm with my calipers. So butterfly is likely the equivalent for USDM and JDM.
Old Jul 30, 2010 | 11:27 PM
Thanks, saves me from having to do it.
Old Aug 1, 2012 | 06:45 PM
mulletboi86's Avatar
Noob question, what is an HDS?
Old Aug 1, 2012 | 07:13 PM
Wanderer.'s Avatar
IDK, but this was a good thread.
Thanks for bumping.
Tauwolf
25
Nov 20, 2013 06:38 PM
bryzem
Mar 1, 2013 04:09 PM
alf74
Jul 25, 2006 02:30 AM
kimo
Dec 20, 2005 04:12 PM
