Some questions 'bout a future Supercharged Fit?
Old Dec 19, 2011 | 11:25 PM
  #41
Texas Coyote's Avatar
Thanks DOHCtor... The gasket doesn't seem very pliable and I am concerned with how well it will do with 10 PSI... I can probably find longer bolts and if a bit too long some flat washers to put enough torque to hold it tight.....
Old Dec 19, 2011 | 11:51 PM
  #42
SilverBullet's Avatar
subscribed
Old Dec 19, 2011 | 11:52 PM
  #43
DiamondStarMonsters's Avatar
If you are worried Tex you could always put a light coat of rtv or silicone on the gasket using a q-tip or something.
It should be fine under boost. When torqued down there will not be a whole lot of surface area, so even at 20psi+, I would wager the gasket is not going to blow out.
Old Dec 20, 2011 | 12:18 AM
  #44
DOHCtor's Avatar
Personately, after having stripped a bolt this summer, i would find 5 studs that are long enough and call it quit!! I will probably do it for the manifolds and for the coil packs when i'm gonna have my engine rebuilded and\or the stock intake manifold back on!
Marko!!
hotkey
67
Aug 13, 2015 06:36 PM
loudbang
14
Dec 30, 2013 12:07 AM
sum76
Mar 23, 2012 10:26 PM
Full2nGD3
Aug 29, 2011 01:08 AM
evo9tofit?
Feb 1, 2010 06:07 AM
