Anyone heard of zage turbo kits?
Old Feb 11, 2016 | 01:38 AM
  #61
Fit Hybrid RS 2012's Avatar
Engine blown due to bad fuel.the car was knocking but race was on.so i kept the paddle to floor.rod broke and went throught engine block and chamber
Attached Thumbnails Anyone heard of zage turbo kits?-img_20160123_110343.jpg
Old Feb 11, 2016 | 01:39 AM
  #62
The damage
Meanwhile another engine was here(a crz swapped k20) so we put that into my car.now i plan on k-swap.ordered the engi9ne from Japan already k20 type R.will take 3-4 weeks to arrive.than i will make a seperate thread about the swap
Attached Thumbnails Anyone heard of zage turbo kits?-img_20160122_161003.jpg   Anyone heard of zage turbo kits?-img_20160122_163709.jpg   Anyone heard of zage turbo kits?-img_20160122_192647.jpg
Old Feb 11, 2016 | 01:45 AM
  #63
Myxalplyx's Avatar
Oh no's man! NOOOOoooooo!
Do you plan on rebuilding it again? What were you racing? Any videos?
Old Feb 11, 2016 | 01:51 AM
  #64
Here is pic after engine swap.
actrually i thought about building with forged internals once engine was out.but than i am stuck with CVT.so if i wanted to increase boost and Hp cvt wont handle it.if i swapped it to manual and build engine than buy crz ecu and hondata etc etc that is costing near a k-swap. a K-swap here is cheap.as labour is less.just 200$ labour :P
total k-swap is costing near 6000$ if i use RSX ecu and K-pro. but i am choosing civic Si ecu and Hondata flshpro.in that way my dash will work and mine and civic si ecu are same generations.with this cost will be near 7500$
Attached Thumbnails Anyone heard of zage turbo kits?-1-80-1656133d1453806647_honda_fit_hybrid_owners_fans_club_img_20160126_135823_19fc3122bcf31d1368.jpg
Old Feb 11, 2016 | 01:53 AM
  #65
was racing on highway speed was above 190KM/H.
Actually the petrol pump who sold me hi-octane was not hi-octane.i found out later at workshop that a supercharged 350z also got blown engine after low quality fuel.I will never refuel from that one but damage alreasy done.but i am not sad.every thing happens for a betterment.
There were no other factors like boost spike,fuel cut etc etc.boost was stable at 6-7 psi and afr at 11.7
Old Apr 18, 2016 | 10:33 AM
  #66
Just k-swapped my fit.its very fun now.
Its JDM k20R motor.we used FD2 R headers,2.75" exhaust,73 mm throttle body,short ram custom intake. civic si ecu was used with hondata flashpro and Haspot engine mounts of crz.
here is detailed thread if some one wants to check
http://www.crzforum.com/forum/cr-z-b...ml#post1106033
Old Apr 25, 2016 | 09:10 AM
  #67
Myxalplyx's Avatar
That's a really nice setup. It does look like it would be a fun drive.
Old Apr 25, 2016 | 01:47 PM
  #68
FamilyWagon's Avatar
Bet that is a lot of fun to drive and surprising to people when they hear that VTEC engage.
Old Apr 27, 2016 | 04:55 AM
  #69
Thanks guys.its lot fun.tyres spin upto 3rd gear!.its MT now so making vids is bit difficult but i made one on highway to record vetc sound.its engages at 5100 RPM,red line 8700RPM.
Another vtec 1st two gears
http://tinypic.com/r/16a7411/9
Old Jun 29, 2016 | 07:04 AM
  #70
here having some fun
Other car is corolla 3sgt swapped.once VTEC kicked in he had no chance :P you all know how agressive vtec is on k20R motors
Inside k20 view
Another run
The blue tye R civic is not tyre R.its R18.
Old Jun 29, 2016 | 07:22 AM
  #71
Old Aug 28, 2016 | 11:29 AM
  #72
345ge8RS5mt's Avatar
Wow...Very nice
Old Aug 28, 2016 | 12:56 PM
  #73
counterFIT's Avatar
I don't know how I forgot about this thread but DAMN I need a K20R
Old Aug 30, 2016 | 10:05 AM
  #74
Where did you find axles?
Old Oct 10, 2016 | 10:37 AM
  #75
axles were custom made.sorry for late reply.i dont check here anymore.but i searched and came to know that k20 axles for EG civic should.but you should contact hasprt or DSS or insane axles for their perspective
Here i made a short clip vtec sound after Greddy muffler install
Here are many pulls.
Old Jan 24, 2017 | 10:00 AM
  #76
Brembovich's Avatar
k20 swap
https://www.youtube.com/watch?v=godSL9bH3vU
https://www.youtube.com/watch?v=rtStR8ctv94
Yea man! your swap very ver very well ? dashboard is work!!!!!!!!!cooool
This my k20a swap into FIT GE8 (SWAP DC5R)
Brembo brakes from DC5+s2000 rotors
And now dashboard not work(because dash GE FIt use CAN BuS)
but i want use 2 ECU...
P.S Tell me please. how you installed shifter
Old Jan 26, 2017 | 09:35 AM
  #77
Nice looking.and thumbs up for brakes.
so your car running finee xcept the speedo and rpm ?
you will need Dakota devices.two of them.one for speedo and other for rpm.once you buy them i will tell you further.
basically you will convert the signals to canbus by thhose devices
This is for speedo
Universal Speedometer Signal Interface
This is for RPM
Universal Tachometer Signal Interface
Old Jan 2, 2019 | 09:08 PM
  #78
Hello every one,The k20 Fit is running great with no problems.I plan on turbo it. Just bought HX35 turbo this weak. i am getting emails about more details of the k-swap.
This is my new k-24 swap build with every details including every wiring,sensor,axles etc etc It covers k24 aswell as a k20 and tells about what will be needed for a k24 or a k20 swap. The main purpose of that build is to prepare evrry thing before the swap and go to swap shop prepared.so that labour and time at shop would be kept to minimum
It is in a CR-Z but procedure is about same except you will use Honda Fit ECU pinout diagram when wiring and axles would be smaller for Honda Fit.
https://www.crzforum.com/forum/cr-z-...-diagrams.html
silverish
37
Jun 16, 2014 01:25 PM
Nighthawk_GD3
Aug 12, 2009 04:06 PM
jits14
20
Sep 6, 2006 10:55 AM
007Fit
Jun 28, 2006 10:42 AM
southwilrise87
May 8, 2006 12:14 AM
