KWSC on A/T @ 15psi
Old Apr 29, 2020 | 12:49 AM
Aliyah Lassiter's Avatar
Originally Posted by lightyear22
So I have my kit installed and am using RDX 410 injectors with it. So now it's time to start working on the exhaust end and I want something with nice flow and a stock sound or a low not annoying sound. Would a axle back do the job or should I go all the way from new manifold to the end? I don't know why I am getting 15psi and change from the SC, I am hoping to get that to 12psi max. I have a tranny cooler for safely and hope the internals hold up to the pressure. I am using a FlashPro to tune the fit. I have Vit from VitViper working on the tune and it is going great. I highly recommend him for your etune if needed with the flashpro. I will post pics and oher info as it happens.
how did you get your car to idle properly with the rdx injectors? I put mine in on my boosted 2010 and it idles rough. My afr is at like 10 which is way too rich.
ryanroland
15
Aug 6, 2012 09:33 PM
kurisux92
17
May 11, 2011 02:31 AM
aallbbeerrtttttt
14
Feb 17, 2009 04:28 PM
chickwithafit
Sep 20, 2008 01:10 PM
