'Mythelogy' lightened crank pulley
Old Nov 1, 2006 | 04:50 PM
  #41
leonine's Avatar
Originally Posted by gettinafit
SUmmit or GTSpec here! Same thing! And it fits all L-series motors! Like ours the L15a1!
No regrets! NOthing but nice accel and Vtec Crossover is felt & audible now! seat of pants dyno is Happy! and if T1R's is on point, the SUmmit pulley is a tad lighter than theirs and theirs made 1.5 hp on an M/T (I have!) so I'm hoping to be getting that much as well!
Actually the T1R pulley LOST 1.5 hp.
Old Nov 3, 2006 | 01:37 PM
  #42
leonine's Avatar
Got my pulley today!
It is sweet! Very nice craftsmanship. weighed in at 1lb 11.5 oz.
Getting it installed next thursday at a local honda motorsports shop.
Updates are coming...
Old Nov 3, 2006 | 02:31 PM
  #43
leonine's Avatar
Dyno Results!
taken from the Mytheology Website
Old Nov 4, 2006 | 06:58 AM
  #44
Rikeys's Avatar
guys just got this from another honda forum maybe its good to share here:
for those who have installed the crank pulley, make sure u get the installer to adjust the belt properly. Mine got some rough 'tak tak tak' sound when the car is cold sometimes, just send back to the SC and they told me the belt tension not adjusted properly. So they helped me to adjust it back. Will test it out tomorrow morning when i start the car.
Old Nov 4, 2006 | 09:03 AM
  #45
kimo's Avatar
Has anyone tried Summit pulley
Old Nov 4, 2006 | 10:04 AM
  #46
leonine's Avatar
let us know the results.
Old Nov 4, 2006 | 10:06 AM
  #47
leonine's Avatar
Getinafit has the summit pulley installed on his Fit. It is actually made by GTSpec which i believe is summit's NA vendor. He likes it but it is not dampened so that is why i went with mytheology.
Old Nov 4, 2006 | 10:28 AM
  #48
Rikeys's Avatar
mytheology????
website says Mythelogy yes?
Old Nov 4, 2006 | 11:31 AM
  #49
gettinafit's Avatar
Leonine, they re-ran the dyno on the t1r on an M/T and it gained HP look at the thread again! But either way, the GTspec pulley is like the T1r's in the way of being non-dampened and light. GT's actually a bit lighter!
If you need someone to do the install you have my number!
Old Nov 4, 2006 | 11:42 AM
  #50
honda_dna's Avatar
does this pulley work on AT? where did you guy get it?? thanks
Old Nov 4, 2006 | 03:59 PM
  #51
kimo's Avatar
Yes you can fit in AT
Old Nov 4, 2006 | 04:55 PM
  #52
gettinafit's Avatar
RavSpec vendor here on Fit Freak.
Old Nov 4, 2006 | 07:08 PM
  #53
leonine's Avatar
GTSpec you can get from RavSpec. Mythelogy you can get from Jimmy101 on this site. Send him a PM. he is their US vendor. Very fast service and shipping and very helpful!
Old Nov 4, 2006 | 07:09 PM
  #54
leonine's Avatar
i have an A/T and it will work fine.
Old Nov 4, 2006 | 07:11 PM
  #55
leonine's Avatar
Thanks for the offer bro! I wanted to have it done local so if there is any problems i have someplace close to home to go. There is a local Honda Motorsports shop that does all kinds of performance mods.
I apreciate the offer though!
Old Nov 5, 2006 | 12:08 PM
  #56
gettinafit's Avatar
Sure no problem. If you want, it might be a good idea, seeing that you are a handy fellow, to get used to taking the pulley on and off for the reason of Honda warranty issues!
Like you said, if something goes wrong with ur motor, you'll just swap out the pulley and tow it to your dealer, they'll never be the wiser!
I would say that it really is an easy install, would take about 15-30 mins. Just loosen the serp. belt using adjusters on the accessories, and buzz the pulley off with an impact wrench. slide the belt back on, and re tighten the belt with the adjusters on the accessories. You are done!
Old Nov 5, 2006 | 02:09 PM
  #57
leonine's Avatar
sounds easy enough but don't i need some kind of measuring tool to check the belt tension?
Old Nov 5, 2006 | 06:59 PM
  #58
gettinafit's Avatar
Nah! Justr make sure that you depress the belt and feel the tension in the same sopt before and after you install the belt! It's the Hand measuring tool! You'll know if it's too loose...SQUEEL!
Old Nov 6, 2006 | 10:36 AM
  #59
Wave's Avatar
How much does the stock pulley weigh again?
Old Nov 6, 2006 | 10:46 AM
  #60
Jimmy101's Avatar
4 lbs, 13oz.
