'Mythelogy' lightened crank pulley
Old Sep 17, 2007 | 04:57 PM
  #141
2hot6ft2's Avatar
Originally Posted by Polish
So it looks like some of you have had these a while now, any issues to speak of?
No issues here.
Old Sep 17, 2007 | 07:16 PM
  #142
Raimondas's Avatar
No problems here...
Old Oct 2, 2007 | 12:31 PM
  #143
07fitsport's Avatar
what was pricing on this pulley??
Old Oct 2, 2007 | 12:35 PM
  #144
leonine's Avatar
i paid around 225 with shipping.
Old Oct 2, 2007 | 01:51 PM
  #145
bangdango's Avatar
I read all the pages on this forum..., but No one really explained it on an MT model. All ive seen is "WORKS GOOD FOR ME!"
Mostly all you guys are autos, thats why im posting.
also..if my car is boooone stock....Honestly...is it really worth it?
Would I feel more of a difference with a chamber intake than this pulley? b/c for the "$225 shipped" I would just get an intake than that, and easily uninstall it if I have to take it to honda for any servicing.
~abe
Old Oct 2, 2007 | 01:56 PM
  #146
leonine's Avatar
~abe
If you are concerned about the warranty then get the intake. It can be easily removed and you would probably notice more of a gain with it. Keep in mind that any one of these parts by themselves are not going to produce "WOW" kind of gains. Multiple mods in conjunction (I/H/E/P) are where you will see the most power.
Old Oct 2, 2007 | 04:19 PM
  #147
Kostas's Avatar
Ι just order the pulley from Jymmy101.
Before and after change, I will count with timer 0-60 and ¼ mile to see the different.
Old Oct 2, 2007 | 04:30 PM
  #148
Polish's Avatar
When you get it please post good pictures of the front and back of it. I want to see if the dampener does indeed go all the way through or not. Thanks
Old Oct 2, 2007 | 05:07 PM
  #149
Kostas's Avatar
o.k. in about 5-12 days to arrive it because I am leaving in Greece.
Old Oct 2, 2007 | 06:18 PM
  #150
Fish's Avatar
Dampener
I was the person who said the dampener does not go all of the way through the pulley. Here are the pics:
Old Oct 2, 2007 | 11:46 PM
  #151
redz jack's Avatar
Latest 'Mythelogy' lightened crank pulley
click to see the result of dyno run...
Old Oct 3, 2007 | 08:52 AM
  #152
Polish's Avatar
Ok so it's true it doesn't go all the way through. Which in turn makes it no "safer" than a solid pulley. Normal dampeners will go all the way through, at least on other cars I've worked on. With the back of that pulley being solid it can't flex so whey they bothered to put in that rubber is beyond me but it may as well be all solid.
Old Oct 3, 2007 | 09:05 AM
  #153
leonine's Avatar
Does the damper go all the way through on the stock Fit pulley?
Old Oct 3, 2007 | 09:46 AM
  #154
Fish's Avatar
Yes it does. I don't have any pics because mine is back on my car. If i remember when I get home tonight I will crawl under the Fit and see if I can snap a pic of the back side of the pulley.
Old Nov 17, 2007 | 11:53 AM
  #155
Kostas's Avatar
So before some days I changed the pulley so I took 2 counter times between stock and new pulley.
My car has CVT transmission box so I did 2 tests first time I put the 2nd gear of “seven speed mode” I step on it from 2000 rpm until the limit revs. So the stock pulley time was 11, 22 and after 8, 97 seconds.
At the second test I put the 4rth gear from 2000 until the limit so the stock pulley time was 23, 04 and after 20, 85 seconds. The only different was that the first time out temp was 21C ˚ and the second (new pulley) was 24C ˚.
So I my opinion is the pulley is worth the money.
The only bud was that the Greek custom stole me.
The final cost of pulley with shipping until my country was 265$ and custom took me another 185$. (I hope them to spend of aspirins)
Old Nov 19, 2007 | 09:15 AM
  #156
Rikeys's Avatar
good timings since less weight
but did you check your top speed before and after this change
Old Nov 27, 2007 | 01:59 PM
  #157
Kostas's Avatar
I know that was 160km/h. I will try some day and i will post.
Old Nov 27, 2007 | 08:22 PM
  #158
SPON FIT's Avatar
is the crank bolt a regular threaded bolt or is it backwards
Old Nov 27, 2007 | 08:52 PM
  #159
koolkevin1107's Avatar
it's a regular threaded bolt.
Old Nov 27, 2007 | 11:21 PM
  #160
SPON FIT's Avatar
sweetness thanks man
