Debadge or Not?
Old Apr 26, 2007 | 01:01 PM
Luichenwai's Avatar
Debadge or Not?
I'm debating on removing the "FIT" from the rear. Or should I leave it? Just want to be a little different and never was too fond of badges. My last car "honda del sol" I removed the H (front and back) and the del sol badge when I had the car painted...
Old Apr 26, 2007 | 01:05 PM
WhatFreshHell's Avatar
I have been considering the same thing.
One of the reasons I haven't gone through with it yet is I don't want people to think it is a new civic.
I think if there were more on the road and everyone knew what they were I probably would be more inclined to do it. It would probably look really nice and clean without badges.
Old Apr 26, 2007 | 01:07 PM
Luichenwai's Avatar
I actually want to do it so people DONT know what it is..... :-)
Old Apr 26, 2007 | 04:43 PM
abcduy's Avatar
I debadged mine, and i stick a newbie badge there instead =)
Old Apr 26, 2007 | 04:56 PM
George02's Avatar
I want to also but dont kno if the adhesive residue is gonna b a pain to take off?
Old Apr 26, 2007 | 05:05 PM
abcduy's Avatar
I didn't find it hard. I used hair dryer and dental floss. Heat up the badge.. and then use the dental floss and move it back and forward. I would recommend using fish line instead though, dental floss broke 3 times.
Old Apr 26, 2007 | 05:15 PM
George02's Avatar
ok so basically let it sit in the sun for awhile then try and take it off? haha I live in arizona!
Old May 2, 2007 | 01:18 AM
vtec-NA.th's Avatar
I also want to know how to debadge it... and how to make it look good without any crap left over.
Old May 2, 2007 | 01:35 AM
abcduy's Avatar
yeah that works..
i debadged it in the winter so i had to pull my car into the garage and heat the badge up with the hair dryer :P
Old May 2, 2007 | 03:00 AM
Zeon's Avatar
Did any glue get stuck when you pulled the badge off? Im thinking about replacing mine with something, or maybe pulling it off entirely, but i dont want to have the big glue spot where the emblem used to be.
Old May 2, 2007 | 07:51 AM
smeister's Avatar
If there is a glue spot left just use some googone on it.
Old May 2, 2007 | 07:58 AM
Luichenwai's Avatar
Well, I went ahead and debadged my fit. Took some dental floss and came right off. For the left over gunk, got some googone and that came right off. Then I waxed that area and its as good as new now. :-)
Now, I want to take the "H" off ....... Thats a whole different story,... probably won't worry to much about that considering I would probably need to take it to a body shop.
Old Aug 16, 2008 | 06:36 PM
ricenpho1's Avatar
is there any way to rebadge it? say on the right side. isn't that how it is in japan?
Old Aug 16, 2008 | 07:26 PM
carramrod's Avatar
Just order the badge and stick it on simple as that.
Old Aug 16, 2008 | 11:30 PM
Rod2Rice's Avatar
Are the H emblems front and rear just glued on also, or are there pins or studs behind it that would leave an open hole in the body if removed?
Old Aug 17, 2008 | 12:12 AM
Wuze's Avatar
The front H is just stuck on and the back has two studs that hold it on.
Old Aug 17, 2008 | 02:29 AM
drzenitram's Avatar
wd40 also works wonders to remove the goo after you remove the badge with fishing line.
the whole process, including letting it sit out in the sun, took about 10 minutes.
Old Aug 17, 2008 | 02:40 AM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
I removed my Fit badge a few days ago. Mine was a pain to get the residue off. I used WD40 as said above.
Looks way better without the badge.
Old Aug 17, 2008 | 03:09 AM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
that would be funny if it left a little "fit" tattoo on the car
Old Aug 17, 2008 | 11:11 AM
RickyGoshDarn's Avatar
I had mine debadge for awhile now, But I just put back on a Fit emblem with a red dot.
