Front Skirt Scrape Protection on Sport Model
Old Aug 1, 2006 | 04:53 AM
fit2bowner's Avatar
Originally Posted by deckwork
My wife used the bulldog product found at
http://www.automotivetouchup.com/spr...nt_primer.aspx
On our odyssey's bumper, and it did a pretty good job. You need to use the adhesion promoter, then the primer, then the paint. Go wider than you think you need to. Really.
Good luck.
Thank you! I will try that.
And it's nice (???--lol) to know that there are lots of us! Just wish it weren't so easy to do!!!
Old Aug 1, 2006 | 06:38 AM
fm2n's Avatar
Yes.. any dip or hill, go down at an angle. The distance from the front bumper to both tires when facing forward is further than the distance when turned 45 degrees. Makes sense? So if the length of the bumper is 25" to the wheel, then once your bumper hits the dip, it has 25" to go before the tire rolls on that surface that has scratched your car. But if you turn your car 90 degrees, then the distance from the scratch to your tire is 0 inches. Since the furthest thing from the wheel is the sidewall of the tire. So at 45 degrees, that would give you twice as much scratch headroom. So your bumper would protrude 12.5" rather than the full 25". Typical lowered car will turn at a 25 - 30 degrees angle. You do the calculations.
I had a 1996 Accord EX that was 1.5" off the ground. It scratched when I went through even a small speed bump. The car looked so nice when lowered, but god, I hated driving it!
Old Aug 1, 2006 | 02:15 PM
JDMish's Avatar
i've been suggesting 3M film to my customers, i havent personally tried it on my fit yet (still on Backorder!) but my 91ef had the same issue. solved the problem on that car.
Old Aug 1, 2006 | 02:33 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
now that is some green grass... something there is not much of here in TX
Outdoormom1
Mar 27, 2016 11:34 AM
Surviver of the Fittest
Jul 6, 2013 11:52 AM
classact2575
Dec 14, 2011 06:14 PM
SalemFIT
Sep 20, 2008 12:09 AM
djk949
Aug 26, 2008 07:09 AM
