Painted Headlights (Black on TW)
Old Jun 27, 2007 | 10:22 AM
  #41
Illusive's Avatar
Originally Posted by Ro_Ja Boy
Send me your headlights and some $ and we'll do it. If you came to Vegas and wanted to do it yourself, I am more than happy to help you with it.
Dammit! I was just in Vegas last week Oh well, was busy for those few days hehe...looks awesome man! I love the flat black over the glossy black!
Old Jun 27, 2007 | 10:39 AM
  #42
Ro_Ja Boy's Avatar
Originally Posted by @fit@
yup, i suggest a local Fit meeting also. should i get flat black or gloss black?
i think JDMchris has gloss blk painted headlight. Anyway i should paint my fog light surround too.
Chris's headlights are the factory ones, so I would do the flat black unless you plan on purchasing a set of OEMs and replacing yours with the OEM black ones. Either way it looks good IMO. George02 is coming from AZ to Vegas next month, so we should plan something for when he will be out here as well.
Ryan
Old Jun 30, 2007 | 07:01 PM
  #43
George02's Avatar
I did mine yesterday, came out really good, but my plastic was really soft and looks wavey now, might just buy oem ones if it gets water in it??? if not Ill deal with how it looks
Old Jun 30, 2007 | 10:25 PM
  #44
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
I was really worried mine were going to come out bad. I think mine look almost perfect. The passenger side looks fine in the housing, when it wasnt installed it looked rough. Little fuzzies were stuck in the paint.
When I installed it I didnt notice it. No one else has either.
Old Jun 30, 2007 | 11:50 PM
  #45
TheGirth's Avatar
I love the way your car looks, congrats. I'm not a big fan of tint for legal reasons but it looks great.
Old Jul 1, 2007 | 02:32 PM
  #46
Ro_Ja Boy's Avatar
Thanks. The plastic does get hot really easily. I have some ideas for the next time that I do it to make them look even cleaner. The only way that you would know that it's not perfect on the plastic is if you popped the hood and looked at it.
Old Jul 1, 2007 | 02:47 PM
  #47
George02's Avatar
yea thats wat sux, because I go to alot of shows.. but I was thinking about maybe just findin some black waterproof tape and just wrap it?
Old Jul 1, 2007 | 03:05 PM
  #48
Posts in the NUUDE
Dude, you should see mine!! Its all chewed up. I also couldnt get the plastic cover/glass back in perfect as OEM so I have little gaps around my headlights and fender. Looks a little better with the little gap though.
When I open my hood no one points it out. So far so good, no leaks or moisture inside the headlights. Ive pressure washed them too as a check. Thank God it didnt leak, that would have been a lot of water.
Old Jul 1, 2007 | 05:05 PM
  #49
George02's Avatar
X2 mine is chewed up also
Old Jul 2, 2007 | 02:12 PM
  #50
Ro_Ja Boy's Avatar
Why was this moved?
Old Jul 29, 2007 | 02:31 PM
  #51
greekdaddy000's Avatar
this is probably the coolest simple mod you can do on a TW Fit!
What materials were used when you put it back together? And for those of you that did it in the oven...what temp. did u set the oven to and how long?
Old Jul 29, 2007 | 03:40 PM
  #52
George02's Avatar
all you need is a heat gun. its pretty simple, the plastic gets really soft so try not to mess with the sides too much? pick one side and pull it apart (its gonna need some elbow grease to pull it apart)
Old Jul 29, 2007 | 03:49 PM
  #53
JDMchris.com's Avatar
I run THIS
if your gonna do it in the stove then preheat to 250 and let it sit about 10 min, i periodically checked mine to make sure nothing was melting
Old Jul 29, 2007 | 07:46 PM
  #54
fits_all's Avatar
but sure is a risky way...
heatguns are like $35,and 80% safer than oven i could say
Old Jul 29, 2007 | 09:38 PM
  #55
DagerOne's Avatar
I would think the oven would be a better way to go...more uniform heating of the seals, and all.
And it looks great. I like the color matched look of my headlights in TW, though. Only thing I'll add...you should have taken out the amber/yellow covers while you were in there.
Old Aug 14, 2007 | 06:00 PM
  #56
untx3's Avatar
I would go with the oven as well. Did the same thing to my WRX headlights and they came out perfect. I was thinking of trying this with my fit and now I know it works the same.
thanks guys.
Old Sep 3, 2007 | 08:19 PM
  #57
pocketrocket's Avatar
so the oven worked ok for you guys? about how long did you leave them in for?
Old Sep 4, 2007 | 11:44 AM
  #58
untx3's Avatar
250 degrees for about 10-12 minutes should be good. Check on it from time to time.
Old Sep 4, 2007 | 01:17 PM
  #59
how did you go about putting the light back together? heat it back up and let it cool?
Old Sep 5, 2007 | 08:44 PM
  #60
joshua27's Avatar
How would a red fit look with flat black headlights and flat black Honda symbols on each end?
