DIY: Taking apart the headlight
Old Jul 28, 2008 | 03:32 AM
BushidoBach's Avatar
very nice.....................
Old Jan 30, 2011 | 10:30 PM
tblue32's Avatar
Painted Head light / fog light bezels
Thanks, Smeister for that DIY, after thinking about it for a few weeks. I went for it and they came out great! Also painted fog light bezels!! Your right it wasn't so bad, just a lot of patience and organization. thanks!!
Old May 4, 2011 | 11:09 AM
smeister's Avatar
Good to hear man!
Old Jun 20, 2011 | 10:22 AM
BallerStatus's Avatar
smiester - thanks man, i did this mod a few weeks ago and they came out perfect. you are a brave sole to try this, but thanks for blazing the way and setting this up for the rest of us!
Old Jun 20, 2011 | 10:53 AM
smeister's Avatar
True! It's not that bad...just a pain initially but once you get started it gets easier.
Love the base Fit look...just like mine but I got color matched mudguards.
Old Aug 27, 2012 | 10:42 AM
Orangetilt's Avatar
Hello everyone! New guy here...
Awesome stuff! One quick question though: Smeister, how did you remove the bowls properly? I tried with a spare headlight and ended up damaging all the mounting points!!
Any tips?
Thank you!
Old Aug 27, 2012 | 11:27 AM
smeister's Avatar
Any tips?
Thank you!
I don't remove them actually.
Old Aug 27, 2012 | 11:50 AM
BlueBoogers's Avatar
Any tips?
Thank you!
As many Fit headlights as I've done, I either end up leaving the bowls in or breaking one of the tabs off and gluing it back on later.
Old Aug 27, 2012 | 03:59 PM
Orangetilt's Avatar
So I guess i should NOT TRY TO REMOVE THE BOWLS! Right!?
When you say you break the tabs, these are those "columns" that support the bolts, right?!
If not breaking, what's the secret then? Drilling and then going around the bowl to access the washers and nuts?
As far as painting goes, I guess a bunch of masking tape will do the trick...
Old Aug 27, 2012 | 04:14 PM
Yep, the columns. I usually snap the one that's best hidden on the GE lamps. I just don't even worry about it and shear it off instinctively.
Old Jun 19, 2013 | 09:55 PM
mugenfit79's Avatar
I just did this and it worked out great except I messed up by cleaning the plastic lens on the inside because I got my finger prints on it and I have swirl marks and its now cloudy instead of clear. Can someone help me out?
Old Aug 3, 2014 | 04:18 PM
  #32
Iradier310's Avatar
Bump
Pictures don’t work anymore?!
Did you also remove the reflector bowl or no?
I tried doing that the other night and it just wouldn’t come off. The adjusting screw wouldn’t let go of it.
Bigaizsosexy
Jul 14, 2023 01:28 AM
GD3 GeGe~
May 29, 2020 02:17 PM
Crawly
Apr 14, 2014 12:58 AM
Jutboy
Sep 13, 2012 11:44 AM
HONDAMATIC
Apr 14, 2010 11:39 PM
