DIY: Adding Brake Light inside Fog Light Section of JDM LED Tail Light
Old Aug 2, 2013 | 02:10 AM
loudbang's Avatar
And the Hybrid ones light BLUE not red.
Old Aug 2, 2013 | 03:21 AM
Subie's Avatar
I hope my experience can help all FitFreak Member
Good job on the post! You're definitely a FitFreak!!!
Old Aug 8, 2013 | 03:16 AM
connor55's Avatar
Don't forget the fit twist! Basically the original base tails but all clear.
Old Dec 10, 2014 | 11:37 PM
BMW ALPINA's Avatar
After almost 2 years, the Left LED that I bought from Amazon almost die and flickering...
I worry I will get ticket because not only it looks like I had a broken light, it also flickering (annoying for the car behind me)...
This time I want to buy a better one even though it is $50 a pair,
because it is a pain to take out all the hot glue that hold the light fitting and glue it back,
so I bought a new pair of LED from VLEDS,
RED PLATINUM 21 LED TURN SIGNAL BRAKE LIGHT BULBS 7443 7444 7440 | 1 PAIR
Notice the metal part is the heat sink:
Here how they package for shipment:
This is how the old glue:
Melting the old glue with my solder then use flat screwdriver to peel of the glue:
Old LED out:
Testing New LED before glue it to the housing, make sure it work,
and the polarity are correct otherwise it won't light up:
Left one installed, Notice how the VLED actually BRIGHTER than the Factory OEM Light !!!
Right one installed:
Hopefully this one last longer than 2 years
Old Jun 20, 2023 | 02:15 AM
slvrsoul.fit's Avatar
has anyone else tried this? i will be attempting this.
if i use a Non LED brake bulb, do i still need to use a diode?
also, does it get brighter when you step on the brakes? or it just stays at one brigthness?
thanks!
kered424
Aug 30, 2015 09:44 PM
DeltaBond
Mar 15, 2014 11:48 AM
chinkieboy
Apr 6, 2012 10:49 PM
InternDoc
Nov 3, 2011 06:36 PM
DanSz
Nov 9, 2008 11:07 AM
