Automatic window switches
Old Jun 2, 2008 | 03:07 PM
isitafox's Avatar
Our UK ones have auto up and down, be worth looking on ebay UK and contacting some of the breakers yards, I'm sure they'd work if connected. Like I said bout my Teg, that had auto down but no up which the JDM one I fitted did and that worked fine!
Old Jun 3, 2008 | 12:15 PM
horwatt76's Avatar
My 2006 Honda Civic EX has the auto up/down feature for the driver's side. Methinks the switches are the same but I'll measure them tonight. It should just be a "plug and play" mod.
-Mateo
Old Jun 3, 2008 | 04:41 PM
mikow's Avatar
yeah, hella work though
Old Jun 4, 2008 | 09:45 AM
horwatt76's Avatar
Yes. And I looked at my switches last night but I haven't removed the panel yet so I don't know if the window switches are seperate from the mirror and door lock buttons (as they all appear to be one integrated piece). Anyone have the Civic '06+ Service Manual?
-Mateo
Old Jan 31, 2009 | 11:02 AM
benmunger's Avatar
Originally Posted by Hootie
Not to jack your thread, but just to add more emphasis on the windows.
Does anyone know how to do the auto up/down function and enable the windows to be raised and lowered via the lock/unlock button on the key fob (Like BMW)?
I did this to my 06 si. After I get the HELMS manual. Ill do it to my Fit as well.
Old Feb 2, 2009 | 03:50 PM
eriko's Avatar
Could you explain how and what you used to do it. I really wouldn't mined having my windows go up/down using my key fob.
Thanks!
Old Feb 3, 2009 | 04:53 PM
benmunger's Avatar
Thanks!
Im going to do it to my fit first and then maybe install them locally for a charge.
I dont need the helms manual anymore... I figured out how to do it. I just need to buy the parts, make the OEM alarm interface, and im good to go.
Old Feb 27, 2009 | 12:54 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
any updates on this.
just in case any GD owners didn't know.
the GE has auto up down on drivers side.
maybe now we have something to work with.
Old Mar 2, 2009 | 08:09 PM
rushlow's Avatar
Acura rsx has auto up AND down. the moving part of the switch looks like its the same size.
Old Mar 24, 2009 | 11:22 PM
HB1320's Avatar
2009 honda accord goes up and down automatic and is for both driver and pass i want them!!!
Old Mar 24, 2009 | 11:28 PM
Fat Ping Cat's Avatar
i want to do this but i don't have the patience or time to figure this out right now... auto up/down on all windows plus control of windows without key in ignition (as long as doors are unlocked) also with the ability to press the unlock button on the remote keyless entry three times and all windows go down and lock to make all windows close
found some info for the RSX:
One-touch Auto Up/Down Windows (DEI 530T) DIY Guide - Club RSX Message Board
you would need two of those modules basically
Old Mar 25, 2009 | 12:24 AM
  #32
runbikerun's Avatar
This might be worth investigating! Thanks
Old May 2, 2009 | 04:13 AM
  #33
CombatBaby's Avatar
i discussed this with some of the electronics instructors at my school, and most auto up/auto down set ups have a custom module wired to them that is obviously not existent in the non auto switches. the module just adds the holding contact type controls so that when the button is depressed enough it can be released and the window still goes down.
i would agree that just getting extra modules and putting them on the other buttons would do the trick.
i don't know how much it would cost, as the modules would doubtfully be readily available. space might also be an issue.
then of course...you gotta decide if the convenience is worth all the extra trouble of tearing the controls apart.
the key fob stuff is a whole different ballgame i think.
did anyone manage to get this working on their fit. i haven't ripped anything apart, but if someone managed to get this working. i'd go through the trouble.
Old May 2, 2009 | 01:26 PM
  #34
jams's Avatar
Well, I have a brazilian made (it's really made in brazil!) 2004 Honda Fit, and here in Brazil every accessory shop sells a module which can easily be installed and does everything you need. It automates all windows UP, and has a timer which enables the power windows for 2 hours after you turn ignition off. But if you leave the car (open a door) the timer turns off after one minute. If you lock the doors, it immediately turns off. Also, everytime you open a door it turns on for a minute. Very useful when entering the car after parking in a sunny place. It also enables closing windows when turning the alarm on. I have this in my Fit, and I added an additional feature: everytime I switch the A/C to recirculation mode, all the windows go up. Makes sense, doesn't it? Why leaving windows open if you want the recirculation? Here's the link for the manufacturer's website: Soft Eletrônica: Alarme, Travas, Módulos para vidros elétricos e Antena eletrônica You have to choose PW42L, then 'aplicação', then Honda Fit, then one of the links to see how to install it. This module, specifically, is made for automate closing windows, but the manufacturer suggest using a second module, just like the first, but installed on the DOWN wires, so that it automates opening windows too.
Old May 2, 2009 | 01:41 PM
  #35
niko3257's Avatar
a aftermarket module will work.
other than that i don't think getting switches will work.
when i had my door apart i noticed that the switch was a
one piece unit with a big circuit board. i don't think thats going
to happen.
rocksnap
Jul 27, 2024 01:59 PM
Cordizzle4life
Feb 10, 2019 09:58 AM
ncoflin
Mar 2, 2016 03:54 PM
Satchel
Jan 23, 2009 03:47 PM
boogie_down77@yahoo.com
Jun 4, 2005 11:09 PM
