AT Short Shifter
Old Feb 15, 2009 | 08:45 PM
  #81
R@ymun2's Avatar
Any updates up this? Has anyone ried using a different shift knob on the AT??
Old Feb 15, 2009 | 09:42 PM
  #82
kylerwho's Avatar
spoon fed
i helped Fitftw install a spoon duracon knob. only one screw to bolt it down and it looks good. pm him to see if he will post pictures.
Old Feb 16, 2009 | 01:29 AM
  #83
ekonetics's Avatar
Anybody know if the 09 TSX leather shift knob would fit on an automatic? I think it would match the sport steering wheels really well.
Old Feb 16, 2009 | 05:49 PM
  #84
HONDAMATIC's Avatar
it will fit but only uses the top screw so it sits higher
Old Feb 16, 2009 | 05:56 PM
  #85
ekonetics's Avatar
Thanks for the reply. I will have to try it soon.
Old Apr 27, 2009 | 04:26 PM
  #86
jhoprodie5's Avatar
Not sure if anyone has already done this for the fit but .... I cut off 2.5" on the automatic shifter and bought the after market automatic shift knob and now its looking sleek!
Basically the shifter has an outer tube and a plastic tube inside. Note that the plastic tube is the one that you push down if you want to shift (park-drive, neutral). Now, what i did is i cut of the outer tube (steel) by 2.5" using a pipe cutter. Note that you need to be careful not to cut the inner plastic tube. Once that is cut of you also need to cut of the inner plastic tube around the same height (used a saw to do this). Then insert the after market shift knob. The shift knob i bout has three bolts around it that is used to tighten it. Note that no drilling was done.
Again, do this at your own risk - Basic disclaimer: I will not be liable for any damage on your car nor this forum.
If you need pictures please PM me your email address and will send it to you. Sorry i dont know how to post so feel free to post the pics.
Old Apr 28, 2009 | 01:57 PM
  #87
MNfit's Avatar
got any pics?
Old Apr 28, 2009 | 03:09 PM
  #88
jhoprodie5's Avatar
Sorry it took a while.
Here are the pics. Used a Momo replica shift knob.
From the back:
Side View:
Old Apr 28, 2009 | 03:39 PM
  #89
chrisng's Avatar
looks awesome nice job!
Old Apr 28, 2009 | 08:26 PM
  #90
isthata_scion's Avatar
aw man i really need that done. good work!
Old Apr 28, 2009 | 10:53 PM
  #91
feared's Avatar
hmm anyway to just lower the factory one?
Old Apr 29, 2009 | 12:16 AM
  #92
secondspassed's Avatar
Not unless you wanna cut it down and use only one of the screws, or tap a new hole below the existing lower hole.
Old Apr 29, 2009 | 12:34 AM
  #93
TekXoID's Avatar
My 08 AT shift lever was too high so I got the 2009 one, I think it's a full inch shorter.
The only difficulty was ordering the 8 dollar plastic back piece that covers the screw on the 09 model. i got the blue stitch leather knob.
edit: pic: http://www.collegehillshonda.com/sto...oshiftknob.jpg
Old Apr 29, 2009 | 12:37 AM
  #94
I have the stock '09 AT shift knob as well, but I don't think it's shorter. It looks more low profile, because it is all black whereas the '08 Sport AT shift knob has about an inch of chrime-painted plastic at the bottom.
Old Apr 30, 2009 | 12:57 AM
  #95
perRYANdrew's Avatar
From the back:
Side View:
cool shifts dude!! how much for labor costs from you? hehe!
Old May 1, 2009 | 06:56 PM
  #96
nicayeung's Avatar
did u do any modification the the pole?
I was thinking about getting that same momo at shift knob for my GE8
how much is that replica?
Old May 1, 2009 | 07:00 PM
  #97
jhoprodie5's Avatar
The only thing i did is cut the outer pole. But make sure that you measure the inner pole and it should poke out the same distance from the outer pole.
I really dont know the price since it was just sent to me from asia. So it must me cheap. =)
Old Jun 23, 2009 | 10:59 PM
  #98
Firefly's Avatar
Bumping for interest...
This is a mod I'm considering doing, but dang the choices are super-limited. I've only found 2-3 universal shifters that might work on the Fit, one is Razo and the other the Momo like jhoprodie5 has. Price isn't so much an issue as making sure of the proper fitment (no major modifications to make it work).
I also saw where someone else on the forum put the 09 GE auto shifter in his and it worked, but I'm not in love with the design on that one. I'm going for more of a luxury look on the interior so, I'm looking for either a leather/alum or leather/chrome shifter trigger style, but apparently their rare for automatics.
Anyone else know of some other aftermarket options? And has anyone tried the tsx one mentioned above yet? It has a leather boot on it so I'm not sure that one would work.
Old Jun 25, 2009 | 06:30 PM
  #99
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
heres the updates:
this my Spoon shift knob ... and its real
sorry they are little to big
Old Jun 25, 2009 | 07:28 PM
  #100
MNfit's Avatar
^^ I had a black one of those on my car for about a month. I dint realy like to way it looked and thought it even looked a bit tacky on a auto car so I switched to a 09 Auto knob and love it.
