Automatic Climate Control
Old Jun 24, 2007 | 08:24 AM
kusojiji's Avatar
Here's a link to the audio console with auto ac control @ japanparts.com:
japanparts.com : PARTS DATABASE
Old Jun 24, 2007 | 05:02 PM
j5ive's Avatar
Remember though, people already found out that the JDM center plates have a different curvature than the USDM models when they attempted to use them to install aftermarket headunits. So essentially you won't be able to use the plate even if you got the ACC unit and wiring sorted out.
Old Jun 24, 2007 | 07:27 PM
kusojiji's Avatar
Wow, that would be a bummer. Do you have links to these discussions? Would be good reading up on this before spending my hardly earned cash.
Old Jun 24, 2007 | 08:32 PM
j5ive's Avatar
here's one of the threads discussing the different curvature of the center plate:
https://www.fitfreak.net/forums/fit-...-usdm-fit.html
Old Jun 25, 2007 | 12:54 AM
kusojiji's Avatar
Thanks, will take a look.
Old Jun 25, 2007 | 01:12 AM
kusojiji's Avatar
Wow, that blows. Please disregard what I posted earlier. I hope that's not the case with the center console. I just bought one from Japan. Needed the armrest.
Looks like my link doesn't work anyway. Strike 2!
Old Jul 2, 2007 | 01:35 PM
tgreaves's Avatar
JDM Jazz climate controls
Has anyone tried to fit the Jazz digital climate controls into their Fit?
I might try this and see if I can make it work.. Anyone know where I can get the Jazz wiring diagrams at?
Old Jul 2, 2007 | 01:43 PM
tgreaves's Avatar
Heres a pic of it..
Old Jul 2, 2007 | 06:05 PM
MouthfulOfchris's Avatar
Old Jul 2, 2007 | 09:36 PM
TheGirth's Avatar
Oh wow, I didn't know there was a digital climate control! Nice! Would it have killed Honda to throw it in as an option on usdm Fit's?
Old Jul 2, 2007 | 09:37 PM
TheGirth's Avatar
I'm very interested in this install? Any updates or new information at all?
Old May 12, 2008 | 09:09 PM
  #32
clovis's Avatar
Installed new headunit the other day in my 07 fit and forgot to remove the plug from the back of the fan speed control and the guts got pulled out when I pulled the dash out. got it back together but it keeps trying to slide back out.
Does anyone know where I could buy the climate control assembly?
its just the white plastic part that includes the fan speed control, temp control, and the position control. Id like to replace the whole thing if I could.
any info would be greatly appreciated.
Old May 13, 2008 | 12:32 AM
  #33
kz098123's Avatar
HA. I did the EXACT same thing when I pulled the headunit on my car too. I broke off the connector of the fan speed control completely cause I forgot to unplug it. I'm glad I'm not the only one!
I just sucked up my pride and took it to my local dealership and explained what I did. After a couple techs looked at it, they figured out what they needed to order, and about a week or two later (after the part came in), they installed it for me. Obviously, it wasn't covered under warranty.
I broke it in the middle of July last year. Temperatures never reached below 90 degrees the entire time I had zero fan speed control. No fan speed control = no fan = no air conditioning. It sucked royally.
Old May 13, 2008 | 02:58 PM
  #34
tgreaves's Avatar
Err.. If you can get me a part# I have a friend who works at Honda and can get the part for you cheaper..
Old Jun 15, 2008 | 01:35 PM
  #35
Charlie97L's Avatar
it's not usually just the control unit, most ACC systems i've seen the guts of are totally different in many ways than the manual.
if you got a whole LHD front cut, you could do it, but even then, it would be a huge pain. it's not just the controls and another box.
salamlaith
Jul 6, 2018 12:09 AM
ljmattox
Sep 24, 2013 07:04 AM
broody
Jul 22, 2010 03:49 PM
HONDAJUNKIE
14
Jul 31, 2008 09:01 PM
Halo
Mar 6, 2006 07:34 PM
