the ultimate slamed fit thead
Old Oct 22, 2008 | 10:28 PM
  #101
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Its a secret. Just use your brain while looking at the rear suspension set-up.
The stance now looks pretty low.
Sometimes I dont even think my car is low. Most entrances I cant enter or exit. A little while ago I was trying to take a new sig pic. I got in the place just fine, exiting I scraped everything possible under my car. (not the lip! Heh) I actually thought I was going to get stuck again.
Need to wait a little while as my dads truck isnt finished. Cant get stuck without a tow.
Old Oct 23, 2008 | 05:49 AM
  #102
JamesBizzle's Avatar
ahh, ok. Haven't looked at the rear suspension but I think I know what you're talking bout (hope I do). thanks
Old Oct 23, 2008 | 12:30 PM
  #103
Posts in the NUUDE
It also depends on the coilovers. I got pics of the HKS coils and you cant do what I did.
I dont think you can even remove the collars. What coils do you have again? I forgot.
Hehh... BTW. I hit a rock on the way to work today. Just a random rock in the road, like 3x1in. WOW, that was loud. Kicked it all over under my car. Im thinkin about getting a metal plate made for my gas tank. Saftey first!
Old Oct 23, 2008 | 02:00 PM
  #104
Ohh really... I'm running T1R B52's.
*looks up HKS and Skunk pics to compare*
Old Oct 23, 2008 | 02:23 PM
  #105
ok, I'm petty sure I know exactly what you're talking about. There's a VERY noticeable difference from the two rear setup. coo.
T1R's are like the skunks.
Old Oct 23, 2008 | 05:24 PM
  #106
Posts in the NUUDE
Just checked pics too. Youll probably only need one collar removed, and lots of rear 1/4 mods.
The rear perches are as big as my modded ones are. Your rears will be able to go lower.
Not sure how the spring will sit with both collars removed though.
Old Oct 23, 2008 | 07:10 PM
  #107
Posts in the NUUDE
Took this today.
Old Oct 24, 2008 | 12:37 AM
  #108
Fit4Trav's Avatar
Ray why can't I take out my rear perch??
Is it because HKS made it so that it was upside down??
Old Oct 24, 2008 | 01:44 PM
  #109
Posts in the NUUDE
Is this what your rear spring set-up looks like?
You should be able to remove it, but removing it will only give you .25in maybe.
Any little bit helps I guess?
I thought the spring wouldnt sit right.
Old Oct 24, 2008 | 06:06 PM
  #110
Fit4Trav's Avatar
Yeah that is how it sits. I could take out the entire thing and run just the spring...but that doesn't sound safe haha
Old Oct 24, 2008 | 06:10 PM
  #111
Posts in the NUUDE
Itll probably fall out. Some guy PMed me asking about that. I wouldnt suggest it.
Your spring also looks way bigger than the Skunks.
Old Oct 25, 2008 | 09:20 PM
  #112
redrumm's Avatar
the collars on the megans are small but for the rear it has a huge base.
id have to take pics to show you but it would drop it really low and i would have to unwind the shock that way i can adjust it to work better.
Old Oct 29, 2008 | 12:46 AM
  #113
redrumm's Avatar
Old Oct 29, 2008 | 05:47 PM
  #114
Posts in the NUUDE
Thats how mine looked.
Old Oct 31, 2008 | 09:39 AM
  #115
MarkyMark's Avatar
how do you 'tuck' your tires?
I just push these
Old Oct 31, 2008 | 04:55 PM
  #116
redrumm's Avatar
really hmm maybe i will take them out
Old Oct 31, 2008 | 09:42 PM
  #117
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
bags=cheating
Old Oct 31, 2008 | 09:55 PM
  #118
Posts in the NUUDE
Originally Posted by Kyle is raaddd
bags=cheating
Agree......
Old Nov 1, 2008 | 11:39 PM
  #119
randay's Avatar
Agree......
anything I cant afford = cheating.
ps. I dont agree! bags ftw.
Old Nov 2, 2008 | 08:18 AM
  #120
Posts in the NUUDE
People with bags dont have any side ffects of being slammed. Speed bumps, bad roads, rubbing, none of that. You all just hit switches and make it look good for car shows.
If you arent slammed daily, its cheating.
