Leak Around the Rear Shock. Inside Car
Old Dec 15, 2008 | 10:30 PM
cowflex's Avatar
Mine rear doesn't really produce any sound. I mostly get odd ? ? wtf noises from my front, rear is pretty quiet. I'm just more worried about how safe it is. I would feel a lot better if some fit members running stock noticed the same thing but we're both running on skunk2 pro c coilovers. So I'm guessing you never got it welded? Sigh what to do I don't want my car to be unsafe I drive around with my gf in it all the time x_x
Old Dec 16, 2008 | 01:27 AM
kylerwho's Avatar
spoon fed
just get the shop to weld around that cup cause it looks like there is some metal fatigue around that cup. tell them the use tig to minimize heat distortion.
Old Mar 6, 2009 | 08:40 PM
LowBUDGETs2k's Avatar
hey ray this happened to me last year i thought it was just me and i happened to do a search and i found this thread...but both my rears leaked water on the pass side i re-tightened it and for months now hasnt leak but for some reason the drivers still leaks and i just throw a microfiber in there to absorb the water lol...wat it looks like is that when i go over bumps the water comes in from that rubber piece not the weld but i dunno..lemme know if you happen to fix your, oh and i have t1r coils doesnt matter if theyre skunk i think its the fit
Old Mar 11, 2009 | 09:31 AM
jdm_gd's Avatar
me too no leak but i have the sound problem. if its wet or snowing the rear makes some noise really annoying but its find once its all dried up. wasup with that
Old Mar 11, 2009 | 04:47 PM
grtpumpkin's Avatar
In the underside pictures it looks like they put the cup in from above with a metal flange that was rolled into the shape of the hole in the unibody by a mandrel. This rather than being welded in place, which would be tricky, even for ASIMO. If that is the case then I would expect a few years of being hammered by your extreme lowness might fatigue that rolled edge enough to leak. I'm with Matt, Manx, and Tyler on this one, if you have welder next door get them to seam weld it (TIG of course) ASAP. Your Extreme Lowness sounds like an honorary title, kinda like, The Grand Poobaah. (ie And now his Extreme Lowness will speak!)
bboarder711
Oct 20, 2019 03:00 PM
mjf123
Apr 17, 2016 02:20 PM
Paulo107
Jun 12, 2014 10:47 PM
veteran13
Nov 1, 2009 04:37 PM
zukered
May 19, 2008 11:03 PM
