Brakes clicking after install
Old Mar 14, 2009 | 01:52 PM
itsmeb*tches's Avatar
Just got done swapping out the brakes on my Fit with Brembo Blanks and Hawk HPS pads. I also changed the fluid and put in ATE super blue. I have a clicking sound when I press the pedal down. It happens around 15mph when slowing down from 35mph. I have triple checked everything.
Thoughts on what it can be?
Thanks.....
Old Mar 18, 2009 | 08:35 PM
lamyun's Avatar
Just some questions:
Did you lube up the slider pins ?
Did you clean (very well) and lube where the pads sit ?
Do the pads fit in perfectly or are a little tight? If you had to force the pads in, they are too tight and need to be filed a bit.
Worse case scenario: Buy a honda caliper rebuilt kit (seals) or get some rebuilt calipers. That's what I did to fix the clicking on my old Integra.
Goodluck!
Old Mar 28, 2009 | 06:21 PM
spoonek4's Avatar
Goodluck!
Good advise!
I know a lot of people just slap on their pads without clean & lube their caliper brackets & sliding pins, either they don't know about it or simply ignore about doing that.
I had two sets of hawk pads on my car. The HPS fits in no problem but the HP+ needs to be filed down a little bit. So u gotta watch out for that like lamyun said.
Old Mar 29, 2009 | 12:50 AM
The slider pins are sealed in a rubber boot. The Fit brakes are not like the old Honda.
After putting the rotors on a lathe, it was found that they were shipped out warped already.
Old Mar 29, 2009 | 03:34 AM
spoonek4's Avatar
There's no clamp to clamp down the rubber boot though. Just like the calipers on the 00' EM1 I had before. They didn't really change anything on these calipers, it's just the same caliper that u can find on a EG6 or EG9.
And the sliding pins gets hella dirty after a year when I service my brakes again. I just wipe them clean & lube again.
Julien Griffault
May 14, 2021 08:04 PM
.eL
Mar 20, 2010 11:30 PM
mikejet
Sep 12, 2009 11:12 PM
setter11
15
Sep 11, 2009 06:49 PM
chibitul
Sep 6, 2005 07:31 AM
